"It depends how patient you are" is probably your best answer.Hi everyone,
If I am opening up Lightroom and DaVinci Resolve at the same time would it be ok to use 8GB RAM?
Sorry, as you don't account for the codecs used your statement is blatantly false. Depending on the source and destination codec the M1 can and will be massively faster than any discrete graphics card!"It depends how patient you are" is probably your best answer.Hi everyone,
See this thread from two months ago. I do not recommend 8GB for your uses. Furthermore the M1 processor will be slow to render video compared to RTX 3060 or similar.
Even the RTX 2060 (let alone 3060) is twice as fast as M1 at DaVinci rendering. It looks like something is wrong with Premier Pro support for M1 and/or MacOS.Sorry, as you don't account for the codecs used your statement is blatantly false. Depending on the source and destination codec the M1 can and will be massively faster than any discrete graphics card!"It depends how patient you are" is probably your best answer.If I am opening up Lightroom and DaVinci Resolve at the same time would it be ok to use 8GB RAM?
That test is not accounting for the source codec. Depending on that source material you need to render a half or quarter size proxy to have smooth playback while editing on the high end graphics card while you can use the source material without a proxy on the M1…Even the RTX 2060 (let alone 3060) is twice as fast as M1 at DaVinci rendering. It looks like something is wrong with Premier Pro support for M1 and/or MacOS.Sorry, as you don't account for the codecs used your statement is blatantly false. Depending on the source and destination codec the M1 can and will be massively faster than any discrete graphics card!"It depends how patient you are" is probably your best answer.If I am opening up Lightroom and DaVinci Resolve at the same time would it be ok to use 8GB RAM?
