Unless I'm testing I don't worry about it that much, with normal shooting, I'll take 3-4 lenses that have focal lengths far enough apart to tell which lens is which(15mm, 28mm, 50mm, 85mm, 135mm), and as I offload the files from the card/camera to my PC, I'll either add the exif data to at least the first shot of each lens or add a txt file to the folder with lens info, I can usually figure out which lens I used well after the shooting date, if the focal lengths are too close to easily tell, I might take a shot with the lens covered between lens changes and do my best to remember what order I used the lenses, this only works if the pictures are of different things, if for example I was shooting only flowers, it's harder to remember what order I shot them because they all are so similar.
Just about every other method I've used forces me out of the creative zone to document the lens and shot number. My Canon 1DIII had a memo function which was supper handy to add lens info, it added an audio file with the same file number to the folder, Chang lens, take a shot, review the shot and add a memo, then repeated whenever you change lenses. I wish all cameras had a similar memo function.
One method I've not tried yet but could work is to set my phone up to record audio at a low bit rate(>128mp3) and just talk to my self as I change lenses, could also take a picture of the phone after you start recording to sync the audio to the camera's clock which would make it easy to find, this would work great for shooting an event and getting names to match the shot.
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
