Displays would be in various aspect rations (ipads , hdtvs etc)The question should be, "Why are there still 4:3 aspect ratio sensors when digital displays have *not been 4:3 for over a decade now".
*except for iPads
Any reasons we should switch? Neither is superior to other. The only sensible upward move would be to build circular sensors and allow any crop from within it. It would be taxing on sensor and lens manufacturing thoughLike smartphones and medium format, any reasons for FF/APS-C not to switch to 4:3 aspect ratio ?
Resistance - yes. Technical hurdle, mostly no except for some compatibility across existing workflowsWill there be lot of resistance ? or a technical hurdle ?
More pixels. 4:3 rectangle inscribed in a circle (circle - our image projection by a lens) would have more megapixels than 3:2 inscribed in the same diameter.Any reasons we should switch?
Many cameras have an option to shoot in different formats. So the 3:2 AR currently in use can remain. Keep in mind, too, that smartphones are typically 16:9 and the 4:3 ratio is cropped.Like smartphones and medium format, any reasons for FF/APS-C not to switch to 4:3 aspect ratio ?
BTW, read about Panasonic GH5S. It have oversized sensor that allows crops to many aspect ratios without sacrificing resolution.But I thought sensor being 4:3 will allow any wider aspect ratio by cropping just top and bottom instead of sides with "lesser" loss in image (though any crop is possible from any aspect ratio) . Would love to hear experiences from experts here
iPads are one of the few exceptions to the rule with 4:3. Go and try to find a home 4k/8k display that's 4:3, or a desktop computer display.Displays would be in various aspect rations (ipads , hdtvs etc)The question should be, "Why are there still 4:3 aspect ratio sensors when digital displays have *not been 4:3 for over a decade now".
*except for iPads
That's right for video but rarely we look at our photos in fullscreen on PC, so it's really not a problem.iPads are one of the few exceptions to the rule with 4:3. Go and try to find a home 4k/8k display that's 4:3, or a desktop computer display.
Surely that's the point of looking at photos, framed the way the photographer intended us to see them rather than burrowing down to 1:1 to see the tiny details or the flaws in the lens.That's right for video but rarely we look at our photos in fullscreen on PC, so it's really not a problem.iPads are one of the few exceptions to the rule with 4:3. Go and try to find a home 4k/8k display that's 4:3, or a desktop computer display.
So we need 1:1 not 4:3 rightMore pixels. 4:3 rectangle inscribed in a circle (circle - our image projection by a lens) would have more megapixels than 3:2 inscribed in the same diameter.Any reasons we should switch?
Circular, with custom crop (can be even done later in RAW). As I already mentioned, the challenge is going to be adapting to manufacture - not just the sensors but lenses too for end to end sharpness everywhereActually, for photography I would even prefer square sensor, like in medium format film cameras (6x6). It maximizes the pixel count for the same optics AND gets rid of vertical grips. No need to rotate camera for vertical shots anymore.
I for sure edit them in the original AR. Sometimes cropped to a different AR, sometimes not. Desktop screens are certainly not 4:3 anymore, so it wouldn't make sense to have 4:3 be a default even for this.That's right for video but rarely we look at our photos in fullscreen on PC, so it's really not a problem.iPads are one of the few exceptions to the rule with 4:3. Go and try to find a home 4k/8k display that's 4:3, or a desktop computer display.
Square gets you more total pixels by area, but the least possible pixels by length. Whether that’s a good thing depends on the subject. For landscapes, square means a whole lot of sky to crop and less width. For portraits, it means a lot of open area on each side of the subject vs a portrait oriented rectangle. You may have to use a wider lens to fit the same subject in.More pixels. 4:3 rectangle inscribed in a circle (circle - our image projection by a lens) would have more megapixels than 3:2 inscribed in the same diameter.Any reasons we should switch?
All the professional cameras? What about Phase One, Hassy, Fuji GFX.We can flip the question - why don't smartphones switch to 3:2 like all the professional cameras?
It would instantly make better use of their whole screens rather than crop out the sides. They even have the sensor, so why do they crop away (either for photos or videos)
Huh? I always view full screen. Why else would I buy a large monitor. No I don’t crop to 16:9, though.That's right for video but rarely we look at our photos in fullscreen on PC, so it's really not a problem.iPads are one of the few exceptions to the rule with 4:3. Go and try to find a home 4k/8k display that's 4:3, or a desktop computer display.
A circular sensor would throw away a lot of silicon on the wafer. Circles don't tile.So we need 1:1 not 4:3 rightMore pixels. 4:3 rectangle inscribed in a circle (circle - our image projection by a lens) would have more megapixels than 3:2 inscribed in the same diameter.Any reasons we should switch?
Which is why I mentioned circular sensor with custom crop.
