My understanding is that sharp lenses, large pixels, undersize pixel apertures and no OLP filtering yield aliased images.
Also downsampling images causes aliasing in monochrome detail, but it is mainly the color aliasing that people object to. "Get a monochrome camera" they say, or "get a Foveon camera," since they mistakenly claim that those do not alias. They do, but just not the particularly noxious color aliasing that's due to the Bayer filter.
But, I seldom see aliasing discussed. So, it seems that few photographers are affected.
Sometimes a scientifically-minded photographer brings up aliasing as a problem, and they often end up being criticized by others who want sharpness at any cost, any detail even though it may be false detail. Consider also the use of AI software which actually does generate false detail on purpose, but hopefully
plausible-looking detail.
I got interested in the issue when I realized that:
- OLP filters are quite complex and come with a cost.
- Large pixels and no OLP tend to alias.
But it seemed to me that photographers like aliased images as long aliasing does not add obvious false color.
You can maybe guess why: imagine spending a fortune on a camera and lens, and then zooming way in, and then only seeing blurry mush. Sharp detail is far more satisfying, even if it looks a bit rough.
Yes, if the sensor resolution matches the resolution of the lens, the result will be soft.
I think one explanation is that many photographers really don't have aliasing in any significant amount. Stuff that is significantly out of focus, which will often be the majority of an image, won't alias. Camera shake, misfocus, motion blur, noise, and lousy optics also contribute.
Yes, I think that all those factors are around. Also I would think that we often don't look that close at images.
This was an interesting case, I wanted to check the poster at the center, it had heavy monochrome aliasing.
Closer crop, note that there is also aliasing on the window blinds.
I didn't want that poster in my image, I was looking at ways to remove it, no easy task.
So, I checked printing it at A2 size, which is my normal print size. At that size it was very visible.
As I would recall, that image was shot on my canon 24/3.5 TSE LII, not the sharpest lens I ever had. But I also have a similar, but different, aliasing pattern with shots using my Canon 16-35/4L.
I would think that the ideal solution may be smaller pixels, with an OLP filter optimized for that pixel size.
This was a 42 MP image. I would assume that a 100 MP image would have much less issues, but it may look pretty soft.
On the other hand, it may be that increasing MP would allow us to use simpler demosaic algorithms. So I think that going up in resolution may be beneficial.
I would also say that this sample proofs that even mediocre lenses combined with high resolution sensors can yield moiré.
Best regards
Erik
Erik Kaffehr
Website:
http://echophoto.dnsalias.net
Magic uses to disappear in controlled experiments…
Gallery:
http://echophoto.smugmug.com
Articles:
http://echophoto.dnsalias.net/ekr/index.php/photoarticles
