As the other posters have said, MC & MD are both SR mounts, this only matters if you are mounting the lens on a native SR mount camera, adapters don't care because there is no communication between the lens and adapter/camera, the lenses are only used in a fully manual manor, so if it fits it should work.
Canon FD SSC and nFD are the only lens mounts that I know of that require pins to be in the proper position for the lens to work properly, every other legacy mount I've used will work when it's not mounted, more specifically the FD lenses only require the breech lock ring to be turned to allow the aperture to function, FD SSC lenses require a pin to be pressed which permits the breech ring to turn, they are otherwise the same, nFD requires 2 pins and the mount to rotate for the aperture to become functional, it is by far the most complicated interlock system to be implemented (that I've used) till digital communication pins.
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
