Jestertheclown
Regardless of your mistake or whatever the OP has done with his image, the fact remains that you immediately decided that noise was a huge problem and that, as always, DxO must dash to the rescue.My mistake was to do an enlargement at all: the OP's image turns out to be a downsize. Perhaps you can explain why Adobe's Super Resolution AI upsizer produced a downsized image?Ah! Name calling again.You really are a twit as well as a clown, aren't you?So, in reality, for all your constantly harping on about Dxo and how superior it is to everything else, you've produced an image, using some Topaz gear, which you're constantly slagging off as being inferior to, yes, you've guessed it, DxO, to achieve a result that's no better; if it's better at all, than the image that you started with.
Your favoured tack when you can't find anything vaguely relative to the subject to post.
You're incapable of taking part in a thread; any thread, without turning it into the DxO appreciation society.
Just for once, would you please just accept that someone, other than yourself, might actually be right and that you're not.
For all your efforts to show us how much better your enlargement was to the detriment of anything that Adobe can achieve, it failed quite miserably.
I pointed out that I didn't think that noise was the issue in this case and I still say it, don't forget that I have sone experience with this software, you've only ever read dubious articles about it on line but you simply can't accept that I might have a point.
In which case, of course, DxO won't be required and that, for some reason, upsets you.
The software does do what it's supposed to.I'm used to software that does what it's supposed to,
I have to assume that the OP's done something else.
Nothing confused in my world.but perhaps this is normal in your confused world.
You're the one with the software fixation.
"It's good to be . . . . . . . . . Me!"
