philzucker
Here a quick comparison for those interested in Zone Plate photography (see https://en.wikipedia.org/wiki/Zone_plate#Photography) of two Zone Plate optics that can easily be used on E-mount cameras:
1. The Skink Pinhole Zone Plate (dedicated E-mount version)
2. Lensbaby Pinhole/Zone Plate optic for use with e.g. the Lensbaby composer or other holders. This optic is only available on the used market.
There is another dedicated one for E-mount available at pinholeresource.com, and of course there should be a lot more, including those for other mounts that can be easily adapted for E-mount.
Now for those two I own - on the left the Lensbaby optic mounted in a Composer Pro for E-mount, on the right the Skink pancake with the Zone Plate installed:
Focal length of the Lensbaby is about 55mm, the Skink offers 15mm. With a Zone Plate focal length simply means the distance from the optical element - a thin film printed with concentric rings in a special pattern - to the sensor.
The Lensbaby has a tiny switch at the bottom allowing to choose between the Zone Plate (f19) or a Pinhole (f177) optic:
The Skink is also flexible, it comes - depending on the kit you choose - with different inserts than are fixed with the screw-in ring in the middle. My kit came with a Pinhole (f87), a Zone Plate (f39) and a Zone Sieve (f56):
In use these two are really very different. Here a picture of a vase with tulips, first shot with the Skink, then with the Lensbaby - for the latter the camera was moved further away due to the difference in focal length to capture roughly the same image. Both pictures were taken on a tripod and with a remote shutter release at ISO 100. They are shown here in full resolution and without cropping,
As you clearly can see the Skink vignettes heavily; it's marketed for "Sony NEX", so APS-C bodies are primarily targeted, nonetheless the vignetting is very pronounced. The Lensbaby pic is much more detailed and sharper, colors are more vibrant. If you look at the Skink picture at 100% you also see a lot of banding, probably because of the very flat angle the light has to follow as it falls on the sensor. That banding can be reduced with some blurring in PP, but it certainly is a nuisance.
Another shot with the tulips closer - again the Skink first, the Lensbaby second. For comparison look only at the right side - the left is very different due to the focal lengths and viewpoints used:
Again there is massive banding and vignetting with the Skink, and better detail and color with the Lensbaby.
But Zone Plate photography basically is not about clarity and sharpness. And vignetting can also used for good effect, and there are lots of possibilities in PP for both optics.
So if you go more for a "painting" look, the Skink might be for you; if you're going more for the "soft focus/bleeding light photography" look, the Lensbaby is definitely the better option IMO.
A real advantage of the Skink is of course its tiny size - it's very easy to have with you, taking up very little space. And it offers a wide angle view on APS-C - the Lensbaby with its longer focal length can't do that, it's better suited for detail shots.
Phil
GMT +1
Gallery: http://photosan.smugmug.com
Phil
GMT +1
