Hello,
I shot few clips to try out my new Fuji X-T4 in 59,96 fps with a shutter speed at 120, codec H265, 200Mbs. It's not an IBIS issue, it was OFF.
When I play the footage straight out of the camera (so MOV file at 59,96 fps in 4K), it works fine but no matter what I do in Premiere, it's stuttering in the software and in the exported video as soon as I slow mo the footage.
It's mostly when panning and moving. If I put the camera on a tripod, filming people passing by, it seems to work fine when in slow mo...
I use this method :
Import footage in Premiere, changing sequence settings to 23,976 fps, make speed duration at 40%. As soon as I do that my footage will be choppy in Premiere and in the exported file as well. (I tried h264HD, h265 4k... same issue)
I also tried :
Import footage in Premiere, changing sequence settings to 23,976 fps, modify clip, interprate footage, assume this frame rate is 24 fps... same issue.
Any idea why?
Thanks a lot,
best,
I use this method :
I also tried :
Any idea why?
Thanks a lot,
best,
