Table of adapted lenses
Maybe I'm the last one to know this, but there's a table showing coverage of full-frame lenses on the 33x44 sensor at:
https://docs.google.com/spreadsheets/d/1uxvvpxJ9QVFFyh0pW2rs9KBmUW9vlh-d-VnbcLDCTn8/edit#gid=0
Just saw the link posted on GetDPI... for what it's worth.
I just found that too today at that GetDPI link. It's a useful resource.
I was surprised to see the Zeiss 21/2.8 Distagon on the list. I used a ZF version as a shift lens on a full frame sensor years ago, and it only gave a few mm.
Another interesting one is the Olympus OM 28/2. It's not surprising that the OM 24/3.5 covers because it's a shift lens, but the OM 28/2 is not. I tested two copies of this lens for my APS-C tilt-shift outfit, and both were poor performers as shift lenses.
Great resource. Thanks for sharing. I wonder how up to date it is. I was directed to trying the 7Artisans 75mm 1.2 M lens for the GFX from an article on the web. Unfortunately, the vignetting was too extreme for my tastes, and you really had to crop to get something out of the image.
Well, of course the lenses already listed don't change so the evaluation is current. But it will only include the newest lenses if people update it. Looks like you can edit the doc by logging into Google and requesting access from the owner. Then add your 7Artisans lens. The owner's email is provided on his website at http://christianschnalzger.de/
Did not know that. Appreciate the info.
Thank you and this table answers many of my questions. I will contribute some data after I got my GFX.
There is no way the 21 ZE/ZF covers 44x33 sharp to the corners at infinity on 44x33. Maybe the person who entered it only meant the vignetting was correctable. I would not base a purchasing decision on this list without finding a second source. No full frame lens below about 100mm covers sharp corner to corner at infinity on 44x33 except some of the most recent tilt/shift Canon EF lenses.
The BSI sensor on the 100/100S should theoretically give a little less vignetting over the 50mp 44x33 sensor, but I've yet to see that demonstrated. That said, the resolution jump to >100mp on the 100/100S is really demanding of full frame lenses designed in the film era. Lenses that I thought were sharp at infinity on my 50S/R really struggle on my 100S. They still render nice images, but they may disappoint at high magnification compared with GF lenses.
Agree, and in fact I wouldn't get too excited about second or third sources either... Anyone else's opinion is simply a rough starting point (and often an unreliable starting point). There are so many variables at play, and a lot of people aren't controlling for them properly.
Time and again I've tried a lens that conventional wisdom says is good, and it isn't on my setup, and vice versa.
Unfortunately, there's no getting around trying for yourself if there's a realistic chance it might work (realistic being the key word here because it's a rare lens designed for a format smaller than the one you're using that works satisfactorily, let alone amazingly).
Friendly amendment on your Canon tilt/shift lens point. I have a Samyang 24/3.5 tilt/shift lens on my GFX 50R outfit. It's not stellar, no denying that. But from f/8, ideally f/11, corner to corner at infinity is possible and results are very good. It's not a lens I generally recommend because I remounted it to get best performance . The native tilt and shift mechanism is kind of crappy, and I'm convinced that some of the problems people are reporting are due to the mounts that Samyang bolts onto the basic lens components.
That's not true. There are indeed non tilt/shift EF mount lenses which are sharp corner to corner at infinity (stopped down). I have two - the Tamron 35 and 45 f1.8 VC lenses. I believe there are others, including from Canon and Sigma. I believe there may also be F mount lenses in this category too, though I haven't personally tested.
Saying that, I'm also highly sceptical of the Zeiss 21/2.8 claim. There are plenty of other fishy claims in the table. A number of lenses listed as covering full sensor had me excited, but when I looked at the sample images linked it was clear that vignetting is extreme and other issues such as corner smearing and cats eye bokeh. The Voigtlander 75s for example.
Still I have found it a useful starting point. Just be willing to do your own research.
1:0 for the skeptics. Here is the Zeiss Distagon 2.8/21 coverage. You get a circular fisheye look on crop MF. Note that this is from the Nikon F version - the Canon might be a bit better due to the larger mount, but not much:
- Chris
- Chris
Thanks for that. You did the measurements?
- Chris
Yes. Lens at infinity on a dumb Nikon F to Hasselblad X adapter. I posted more of these some time ago:
https://www.dpreview.com/forums/post/65966044
Really useful work you're doing.
“Black corners” and “strong smear” are a strong double indication to me that it isn”t covering 44x33 respectably well. But it’s been almost two years since you wrote what I responded to, and the table may have been updated in the interim.
If the entry amounted to a positive I would agree. But it looks damning to me. I did actually own one once, and was bothered by the smearing on 24x36. The same goes for the ZF 15mm even more so
I think that the Sigma Art 40/1.4 does pretty nicely with a soft and faint corner darkening after applying Fringer’s lens profile. It’s not far from the not-jarring creative vignetting that I frequently do. But do get a 2nd opinion 😊.
Wag more; bark less.
Thanks, Jim! I guess I should gather these in one place where they are easier to access. One thing I’m curious about is how much better the 100 MP BSI sensor does. My measurements indicate that the sensor has quite a large effect, in that the curves for the longer XCD lenses are closer to the figures published by Hasselblad than those for the 30 and 45mm. I’d have to put some work into the program I wrote to produce them (mainly documentation) before it would be useable by other people. Also, it uses dcraw and thus does not support Fuji raw files.
- Chris
I had the Zeiss ZE 2.8/21mm, ZE 2/35mm, ZE 1.4/50mm and ZE 1.4/85mm adapted to the GFX50R with the Kipon EF>GFX AF. I sold them all.
2.8/21mm: horrible hard vignetting with no chance of recovery except with a big crop in the image and distortions.
2/35mm: vignetting and chromatic aberrations.
1.4/50mm: very bad between f1.4 and f2.8; lack of contrast and sharpness. Vignetting and chromatic aberrations.
1.4/85mm: very bad between f1.4 and f2.8; lack of contrast and sharpness. Softest vignetting of the four and chromatic aberrations. At f1.4 there was a very strange effect that looked like an "Emboss".
It's no coincidence that the 1.4/50 and 1.4/85 were completely redesigned when they became Milvus. They are beautiful objects but optically weak. Why have f1.4 if you can't use it? Apart from vignetting, these problems were present when I used them on the Canon 5DII/III/IV and EOS R cameras.
I now only have the ZE 2/100mm Macro-Planar. It does a bit of vignetting (recoverable) and optically it's superior to all the others I've mentioned. The Zeiss APO Sonnar T* 2/135mm ZE/ZF2 is very good too.
This table isn't always accurate, but it has its uses.
I'm curious to know how the Carl Zeiss Planar 2/50mm T* ZM - Leica M Fit behaves in the GFX with respect to vignette. I hope it's better than the ones I had :-) If anyone has already tested it, I'd be grateful if you could share your opinions and, if possible, images. Thanks.
Most normal to wide M lenses are a bit worse than the same focal lengths designed for other 35mm mounts. The M lenses are so small, Leica has to use extremely thin cover glass and special microlenses on the digital Ms to accommodate the angles at which light from M lenses is hitting the sensor. The GFX cover glass is not only very thick but is also gapped away from the sensor. But like many other 35mm/full frame lenses, some M lenses can be used at close distance wide open for portraits, etc.
50 Summilux ASPH at f/1.4 on the 50SII (the smeared corners do not go away when stopped down):
