Sony ZV-1 Self timer and focus?
Akinnfenwa
New member
Hi,
My first time using a proper camera. I was trying to shoot some self-portraits but all photo's are unsharp.
I found out that it is because the camera focuses when I press shutter button and when I'm in the field, it focuses not on me. It doesn't refocus, also not when I do interval shooting.
How do I fix this?
Is there no way to let it focus each time when it shoots a new photo?? Or after 3 seconds from the self timer?
Yes, Sony cameras like to autofocus at the moment the shutter release is pressed and don't refocus for the moment of exposure after the self-timer count. It's annoying.
How do I fix this?
You can't. You have to take a different approach.
As mentioned above, you can trigger the release remotely instead of using the self-timer.
Another option is to use the Smile Shutter feature.
No.
Hi,
How do I fix this?
That's classic Sony behavior. You'd expect a "self-timer" to be useful for taking photographs of yourself, wouldn't you? Sony disagrees, and has done so for decades. On Panasonic, in contrast, prefocusing with half-press shutter in self-timer mode will retain the focus like Sony does, but pressing the shutter fully immediately will cause the camera to focus after the self-timer has run off.
Any clever combination of other features (like multiple shots or continuous focus mode) that would appear to provide a way to get around this problem is consistently being sabotaged by Sony. The manual states that all those will not work without bothering to mention a rationale (to be fair: mentioning a rationale is not common for any decision by any manufacturer).
Buy a remote trigger (or use equivalent features) and forget about the self-timer.
Hi,
How do I fix this?
Certainly, for selfies, it's much better to use a remote app on a phone or tablet. You can see exactly what it's focusing on and review shots, all without touching the camera.
It's still worth using a delay timer in both the app and the camera, so you can be looking at the camera, not the phone, when the shutter firrs.
Hi,
How do I fix this?
Also gives you the time to stuff that tablet into your pocket to avoid looking like a tool of our time.
Hi,
How do I fix this?
Yes, though a phone is the more likely choice. Of course, by keeping the phone in shot, you can demonstrate that you weren't using it to take the selfie!
Hi,
How do I fix this?
You are right in that I lag behind the times in my visions. The reality these days likely would be more like
"Siri, take that shot! And I don't want yet another crotch closeup pointing out where I stuck the phone."
Hi,
How do I fix this?
Try pre auto focus mode where the camera constantly adjusts focus until the shutter is released. I never have used this AF mode but it's worth a try.
Hi,
How do I fix this?
Maybe Sony got a clue after all these years?
But even the ZV-1 manual states both:
"Use the 5-second/10-second self-timer when you are going to be in the picture,"
as well as
  • Adjust the focus and shoot the image.The self-timer lamp flashes, a beep sounds, and a picture is taken after the designated number of seconds have elapsed.
which does not fit well together. Maybe it's merely a copy&paste from older manuals and this camera indeed is different... But I doubt it.
And pre-focus is not described as working before the shutter is released but before the shutter button is pressed:
"The product automatically adjusts focus before you press the shutter button halfway down. During focusing operations, the screen may shake."
But maybe you are lucky.
