Belgarchi
To evaluate field curvature is very important to rate and to use a lens.
If, as often, especially for wide-angles at large apertures, the corners of an image are less sharp than the center for a flat subject, you should determine if it is due to field curvature or due to other aberrations.
Field curvature is less of a problem if you know it is there, allowing you to get objects in front of the focusing plane sharp.
The procedure takes less than a minute: put a detailed subject in one corner of the image, focus on it, look at the same subject placed in the center of the frame. With my Fuji X-T3, no need to take a photo, the viewfinder is good enough to see immediately if there is field curvature (you must change the focus to reach maximum sharpness in the center) or not.
