Hello again,
so I've been trying to do some test with the lens and even cleaned it too, but it didn't get any better......
It's also time to write a letter to Santa, so my question is: If I were to buy a better lens, maybe even a better camera, what would you guys advise? Since there's no holidays coming due to Covid I think Santa might be generous! and I really really want to be able to get better results straightaway and also be able to use the same camera for a long time. What would you guys suggest/recommend? I wouldn't want anything that only a pro could use, equally I would like something with a bit of life still in it. My budget would be around 3000-4000USD for a camera with a telephoto lens.
You already have a camera body so you might think about looking for a lens'
Right now there are a great deal of lenses out there that can give you better results
Sigma and Tamron make 100-400 zooms that will keep your weight down
Sigma and Tamron have several lenses in the 50-600mm range
Nikon have the 200-500 I have only used the lens briefly but it is a contender for IQ on a budget.
If your heart is set on purchasing another body the D7500 with any of those lenses will give very good results.
There is also the chose of looking for a used body the D500 is king for cropped.
And if your heart is set on using FF there are deals on the D800 and D810 that are to good to miss and the difference between the D810 and D850 you really need to push the camera to the max to see a difference.
I went with the D800 and added the D810 for my wildlife setup I also use the sigma 150-600 sport as a bet dirty lens and enjoy what it can do
I would not be surprised that you could find a D810 and sigma sport for well under your budget
If you are looking for something more the Nikon 500 ƒ/5.6 is another lens that I would consider for it size and weight.
There is also another lens that gives you much of the bells and whistles as the top pro lenses out there the 200-400 F4 and 200-400 F VRII. Both can be found at bargain prices and this is my primary lens for wildlife.
Two of the biggest hurdles you will face is placing yourself into the conditions that are needed to photograph wildlife and using the equipment at its best strengths.
Even with cheaper and less resolution cameras just understanding how to get the shot will go along way
This was taken with the Pentax K10d and the beater sigma 50-500mm lens that was not very sharp
