Tom Axford
That applies to all of us who keep these threads going! ;-)I think you must be pretty bored :-D
Using quarters and nickels is not exactly metric.They don't need to know the origin, only how to use them. Most instruction manuals give a decent outline.Anyone getting into photography can't figure out where the numbers come from.
OK, you go first.Actually, I think Olympus tried to fix that by using numbers from 1 to 6 in their PenF film cameras. Can't we come up with something new that would make more sense?
I know of at least three more countries that do not use metric for everything. And US currency is metric already.But it probably won't come from the US. We keep on using the archaic inches, feet, mile, oz., gallon, etc. Only two other countries besides us do't use the metric system, they are Burma ( Myanmar for the young whippersnappers! ) and Liberia.
I think you must be pretty bored :-DWe're in good company!
Let me know what your thoughts are.......
Nope, f/stops are based on a physical attribute so there's no reason to change it.Anyone getting into photography can't figure out where the numbers come from. Actually, I think Olympus tried to fix that by using numbers from 1 to 6 in their PenF film cameras. Can't we come up with something new that would make more sense?
But it probably won't come from the US. We keep on using the archaic inches, feet, mile, oz., gallon, etc. Only two other countries besides us do't use the metric system, they are Burma ( Myanmar for the young whippersnappers! ) and Liberia. We're in good company!
No it isn't. Metric means based on the metre invented during the French revolution; most metric units are in factors of ten (decimal) from their base.I know of at least three more countries that do not use metric for everything. And US currency is metric already.
I learned "bigger is smaller" sometime in the dark ages before I was 8. My mom asked me to get knitting needles out of the cabinet drawer. They use inverse size numbering. I dealt with it. By 12 I was building Heathkit educational kits to learn electronics. Gee, wires are just like mom's knitting needles because those larger numbers in gauge mean thinner wire. I got it.Modern lenses are metric. When the US and the UK had larger optical firms they sold in inches.Lenses are metric. All millimeters as far as I know. F-Stop math was learned in elementary school. Once someone is shown what it is, it’s really easy.
F/Stops are the "new" answer. There have been other methods in the past.
The only real problem is making people understand bigger is smaller.
A centimetre is 1/100 metre (or 1/10/10) - factors of ten, just as I said. A litre is the name given to that unit of volume in the metric system. A kilogram isn't also known as a litre; it is the mass of a litre of water.Kilogram aka a litre of water aka 1000 cubic centimetres is metric.I know of at least three more countries that do not use metric for everything. And US currency is metric already.
Insofar as the US currency is based on the dollar and cents (1/100ths) it is a centimal system; as 100 is 10 x 10 it could be called a decimal system but not a metric system.
It is an entirely independent system of measuring temperature, alongside Fahrenheit, Reaumur, Kelvin etc. The basis of many temperature systems is the range from the (normal) freezing and boiling points of water. Celsius chose 100 as the number of divisions; as that fits with the decimal basis of the metric system Celsius was adopted into it.How does Celsius fit into that?
In practice the original metric system has been used as the basis of the SI system.
That's exactly what I said.The only thing Celsius chose is that 0 is freezing, 100 is boiling.A centimetre is 1/100 metre (or 1/10/10) - factors of ten, just as I said. A litre is the name given to that unit of volume in the metric system. A kilogram isn't also known as a litre; it is the mass of a litre of water.Kilogram aka a litre of water aka 1000 cubic centimetres is metric.I know of at least three more countries that do not use metric for everything. And US currency is metric already.
No; read what I said. Such systems are decimal, not metric. The metric system is, of course decimal.The rest just kind of fell where it may. At least that’s my very limited understanding. But even numbers like that is why they likely say it’s more metric in nature.
There's nothing silly about it. However, apart from learning a few points along the way (like blood temperature is about 98F, 37C) that don't matter for everyday living, a decimal system is much more convenient for any calculation that uses computers.Whereas Fahrenheit is 32 freezing and 212 boiling. Which I totally get why people outside the US think it’s silly. But when I hear it’s in the 70’s I know it’s a nice day, grab a jacket below 50 or a coat below 30. That’s just intuitive to me being in the US. If hear an non- US forecast - I know the 30’s is warm but really no idea between pleasant warm or uncomfortably hot.
Interesting; this was new to me so I looked it up.That was used on the FT version and you needed the new lenses marked with those numbers to take advantage of it (so setting the lens on 1 when the light meter was on 1)Anyone getting into photography can't figure out where the numbers come from. Actually, I think Olympus tried to fix that by using numbers from 1 to 6 in their PenF film cameras. Can't we come up with something new that would make more sense?
However those lenses also had the standard f number on the other side.
now explain to me how having number 0 on a lens is more intuitive than f/4 ?
Note that 0 on the other lenses can be 1.4/1.8/3.5/5.6 ....
BTW, why do you think the system was not used again after that ?
T stops are not needed for stills, because the transmission of modern multi-coated lenses is so good that the difference is negligible. They were needed when people were shooting movies with uncoated lenses.I'd prefer we go to T stops. Not sure why still lenses, especially high end ones, don't use that system. I'd rather have a gauge of actual light vs fstop. Tony Northrup came up with a system based on Tstops, but linear, and based I think on total light not intensity, so that it accounted more for DOF etc than exposure. I remember thinking it just sort of substituted one problem for another, but you can see for yourself:And yet, we all got into photography at one point or another.Anyone getting into photography can't figure out where the numbers come from.
This is first day of Intro to Photography, easily mastered.
For those for whom it's too complex, you have scene modes with a choice between mountain or face.
That's because we can handle numbers besides 10But it probably won't come from the US. We keep on using the archaic inches, feet, mile, oz., gallon, etc.
Seriously, nothing against metrics and it is sensible. But so are f-stops.
Edit: If there was any compelling drive for an alternate system, I'd use the exponent that gets you to the f-stop where the base is sqrt(2).
So 0 is for an f-stop of 1.4^0 (f/1)
1 is for f/1.4.
2 is for f/2
3 is for f/2.8
And you can go below f/1 with negative numbers:
-1 is f/.7
I don't think that makes anything any less complicated other than making it clear that 6 to 7 is one stop (instead of 11 to 16).
- Dennis
Gallery at http://kingofthebeasts.smugmug.com
The F numbers apply just the same to lenses with the focal length and aperture diameter marked in inches. They are ratios,Lenses are metric. All millimeters as far as I know. F-Stop math was learned in elementary school. Once someone is shown what it is, it’s really easy.
Many people do suffer from having been taught basic maths badly, so that they don't understand fractions and ratios. But you aren't doomed to stay ignorant all your life just because you had a poor teacher when you were eight.I actually sort of like that. Having taught photography at college level, I know from experience that a lot of beginners have trouble with f numbers. Far more than some here seem to think. I've known a good many working professionals who didn't really understand it -- they just know there's a tradeoff with shutter speed.You don't propose any alternative?
I really don't think they are going to change anytime soon, but if the square root of 2 is too obscure, then just square it. Instead of using the focal length divided by the entrance pupil (the definition of f-number or f-stop), why not just square it and use that?
That would have the advantage that the sequence would change from 1, 1.4, 2, 2.8, 4, 5.6, 8,... to 1, 2, 4, 8, 16, 32, 64,... .
I can't see it happening, but with digital cameras it would not be that difficult to offer both and give the user a choice as a menu item. So not too terribly difficult if camera makers wanted to do it.
Gato
Well, before thinking about something new to replace 'f-stops', why not start with the biggest nonsense in Anglo-Saxon photography speak, calling an 'exposure time' a 'shutter speed' ???Anyone getting into photography can't figure out where the numbers come from. Actually, I think Olympus tried to fix that by using numbers from 1 to 6 in their PenF film cameras. Can't we come up with something new that would make more sense?
Especially when exposure time can equally mean the time at which the exposure was made - which is shown whenever EXIF is included with photos here. It's should properly be called "exposure duration".Well, before thinking about something new to replace 'f-stops', why not start with the biggest nonsense in Anglo-Saxon photography speak, calling an 'exposure time' a 'shutter speed' ???
