30-year-old manual lens impressive on the R5
xtam667
Forum Enthusiast
Bought a Zeiss Planar 2/45 for Contax G out of curiosity after reading that it was touted in the early 90's as the sharpest lens for 35mm film so far. This is it with the RF mount adapter:
Small and beautiful
Small and beautiful
After trying a few other "very sharp" vintage lenses from the 70's I had no big expectations. I just was after a nice classic Zeiss rendering. I was prepared to put up with some corner smearing, colour shifts and vignetting associated with short rangefinder lenses on modern digital bodies.
Well, this petite lens packs a big punch on the R5. It is very sharp in the center at f2. One can see pronounced vignetting, mild softness at mid-frame and bad corners. Bokeh is below average. However, clarity and contrast is very good already, except in the corners. At f2,8 most of the softness is gone and by f4 things are beautiful overall. At f5,6 and f8 this lens is extremely good across the frame. I tend to pixel peep but at these apertures I see no flaw whatsoever worth mentioning. There is some flaring and minimal CA if you really want that to happen but contrast holds up very well.
Almost all prime lenses are sharp at f5.6 so this is nothing special in itself. But not many are bitingly sharp in the center wide open with a gracious fall-off and few are so consistently very sharp across the frame at smaller apertures. Even fewer have the nice contrast, clarity, colour rendering, and out of focus transitions that this lens can produce. Yes, this is subjective and you can always tweak in post to a degree.
Modern lenses that are better cost more and are huge by comparison. Those comparable in size cost 12 times more while not really that much better and do not play nice on digital except their own brand (looking at you Leica).
This is how it compares to the smallest Canon lens, both adapted to the RF mount:
Smaller and much better built
By the way, the little Canon 40/2,8 is a steal and I really like it. I used to put it on the 1DX for fun point-and-shoot. People literally ignored me. A big lens on a smaller camera attracted much more attention. Apparently, perceived professionalism is a factor of lens size and not camera size, but I digress.
And now the bad news. First, this thing has no focusing ring! Contax G cameras are weird autofocus only rangefinders. A motor in the body drives the lens focusing mechanism through a small and not very confidence-inducing screw. There are a few adapters that can be used, all bad when it comes to focusing experience. Forget smooth.
Second, the bokeh is really not that good. The hexagon-shaped iris surely does not help.
Third, although the lens has electric contacts and can report focal length and probably aperture too, the adapters ignore all that. So no lens EXIF data, which is OK for a lens that does not know anything about itself, but this one is at least halfway to self-awareness :)
Finally, two casual shots processed to taste in LR without any lens corrections. Sharpening 100, radius 0.5, detail 37. Keep in mind that this is a $350 lens. What do you think?
Planar 2/45 at f8
Planar 2/45 at f8
Planar 2/45 at f2.8
Planar 2/45 at f2.8
Thanks! Nice pictures. Perhaps technology hasnt improved as much as we imagine in the past 30 years...
There is a parallel here: 50 year old recordings were made with microphones that actually sound better than modern designs. The new mics measure better, and they are clear; but they are not as musical as the old hand-made mics of yesteryear.
David
That's a good parallel. Some of my best sounding albums were recorded in the 60's and 70's.
With this lens I think it helps that it is not particularly fast and of standard focal length. With very few exceptions wide lenses did not age as well.
That's a beautiful looking lens! I love using vintage glass on my R5, it's been a few months since I last bought one and I'm sort of itching to acquire another... Can you explain more about the auto focussing with this lens please? What adaptor are you using?
Rose
Rose
https://www.facebook.com/roseatkinsoncreative
As far as I know there is no autofocus adapter for the RF mount so you need to focus the lens manually by turning the ribbed ring on the adapter, which in turn drives the focusing mechanism through some internal gearing. It is not a pleasant experience but works well with the nice viewfinder and manual focusing aids of the R5. There is an autofocus adapter for the Sony E mount, but from what I hear it is pretty bad.
I use the Kipon Contax G to RF adapter. Fotodiox also makes one but I was less happy with that.
The Planar is vintage glass but its rendering is very modern. If you are into the real vintage look then check out the C Sonnar 1,5/50, which is the opposite. It is one of the most beautifully rendering normal lenses in my opinion.
C Sonnar 1,5/50
C Sonnar 1,5/50
Rose
C Sonnar 1,5/50
C Sonnar 1,5/50
Interesting! Thanks :)
Rose
