Nikon AF-P DX 70-300 - DX vs FX on Z50!
Byku
Member
Recently I had the opportunity to own both FX and DX version of this lens. Here I will give you some comparisons between both lenses. Shoot in JPEG, neutral profile, no ADL active, manual settings.
First - moon:
Left: DX - at 300mm, f/8, right: FX - at 300mm, f/8
It seems that we see a bit more details in bright parts of the moon, and on the edge of the moon the FX version is a bit sharper, but the differences are marginal.
Second - chimney, bright sky in the background.
Left: DX - at 300mm, f/6.3, right: FX - at 300mm, f/6.3
Dx version suffers a lot more from chromatic aberrations. It seems that it's also a bit less sharp, and we don't see as much details in the dark part as on the FX version.
Third - building far away:
Left: DX - at 300mm, f/6.3, right: FX - at 300mm, f/6.3 - center crop
Sharpness seems very similar, although DX version show more chromatic aberrations near the gutter at the top.
Left: DX - at 300mm, f/6.3, right: FX - at 300mm, f/6.3 - a bit below center
Fine details - FX version seems to resolve them a bit better.
Unfortunately I forgot to disable vignette control :/, but still, even with it on - the FX version has less vignetting than DX one.
Left: DX - at 300mm, f/6.3, right: FX - at 300mm, f/6.3 - left corner
FX wins, in DX version you can notice chromatic aberrations removal artifacts.
Now let's see how they compare at f/8.
Left: DX - at 300mm, f/8, right: FX - at 300mm, f/8.
Left: DX - at 300mm, f/8, right: FX - at 300mm, f/8 - center
DX shows more chromatic aberrations(gutter at the top), sharpness seems to be very similar.
Left: DX - at 300mm, f/8, right: FX - at 300mm, f/8 - corner.
FX wins again.
Summary - in center both versions are very similar. Chromatic aberrations, vignetting and corner sharpness are better on the FX version.
Excellent comparison, and one that I hoped to see.
All in all, that little DX lens does a pretty good job at about half the price and size of the FX version (if that's all you need -- I've got both formats).
I have always heard that the FX version is better, and I guess you showed that it is. But it is not a big improvement.
Link to full res photos(forgot to add it):
https://flic.kr/s/aHsmSrs1y9
Oh and I've showed different parts of the wall when comparing the "fine details". Sry, here's the proper comparison:
FX on the left at f/8, DX on the right at f/8.
FX still a tiny bit better.
First - moon:
FX wins again.
You magnified the FX samples in order to match the equivalent focal lens, right? Impressive the quality of the FX version...but it costs double :))
