Hi all,
I have A7R III with 24-105mm f4 and I sometimes find myself wanting to go a bit wider when shooting landscapes.
My considerations:
This leaves me with 3 options:
Samyang 18mm f2.8 - very cheap way of dipping my toes into UWA territory, very compact, but according to reviews not the sharpest alternative across the frame with reputed large variation among copies due to which I was never a fan of Samyang.
CV 15mm f4.5 - I love the idea of this lens, but 15mm is quite wide, perhaps too wide? Unfortunately, CV does not do anything between 15mm and 21mm.
Tamron 17-28mm f2.8 - at the push of my budget, Tamron would give me the flexibility to explore the wide end a bit more (17-18mm look vs 20-21mm look), but I would probably be shooting it mostly at its widest, so I am questioning the real world benefit of the flexibility. How does it perform vs the Samyang 18mm?
Any opinions, user experience or alternative suggestions are welcome.
Many thanks!
My considerations:
- size (not weight) - I have a 5l Peak Design Sling and the lens has to fit there along with the camera and 24-105mm. 80mm dia x 120mm length is an optimal maximum size to squeeze a blower and filters in as well.
- across the frame sharpness performance comparable to my 24-105mm @24mm
- has to take standard screw-in filters
- should be a reasonable astro performer
- up to ~£600, I would not mind buying second-hand
Many thanks!
