The 35 Summicron ASPH that the OP implies he already has is current rather than vintage. And if he does have it and does not want to conserve funds for now, an inexpensive but good quality APS-C camera like a Fuji X model works very well....if you want to go to the trouble of shooting an M35 (especially if a vintage lens), then do yourself a favor and pair it with a digital or film M.
But this is his 2nd post:The 35 Summicron ASPH that the OP implies he already has is current rather than vintage. And if he does have it and does not want to conserve funds for now, an inexpensive but good quality APS-C camera like a Fuji X model works very well....if you want to go to the trouble of shooting an M35 (especially if a vintage lens), then do yourself a favor and pair it with a digital or film M.
That post is not from OPBut this is his 2nd post:
Following (but my choice would be the v4 M Summicron).
+1[...] Regarding the original question: I'd look for a used M240.
www.instagram.com
Leica Ms are tough, I had an accident, brand new bike a spoke broke when I was doing a good down hill. My M3 was in a back pack which I landed on. I had a 35 on the camera with goggles. Because of the goggles the 35 was sheared off the camera. Other than the pin holding on the lens on the camera, the body checked out fine. The lens needed a new mount otherwise it was fine. Because it was in a back pack there were no marks to the camera. Now I carry the camera in a handle bar pack, I use a Domke insert or foam for padding. Seems the safest way to carry a camera.I am looking for something similar to what you want, only for a different reason. I'd like to locate a cheap body on which to use my existing Leica lenses when I'm cycling. The bike sustains some serious jolts and I don't want to damage my M Type 262.
Good for you! I'd be interested in comparisons, especially with the 35, between the Lumix and a Leica sensor. I'm thinking 35 is pretty much as wide as you can go without some evidence of corner smearing when comparing IQ.I just picked up an Lumix S5 and it plays very well the Summicron 35mm f/2 ASPH (and 50/1.4 Lux ASPH). I'm using the Leica M-L adaptor. Hard to beat the price.
the cheapest digital body new is the Pixii announced on this site ...used they will probably go for much lessHello folks,
I want to swap the Q (28mm) for the Summicron-M 35mm f/2 ASPH and an affordable body, the m10-r being too expensive. Any recommendations?
I was researching wide angle lenses (M mount) and adapting on non-Leica cameras.. i stumbled on this article that compares native Leica vs Sony (modified sensor stack). Interesting the 28mm corner difference... https://blog.kasson.com/the-last-word/kolari-thin-stack-mod-on-a7ii-vs-m240-leica-282-8-elmarit/My understanding is that it isn't just a matter of wider is worse; some lens designs are worse than others because the rear element is so close to the film plane. In any event, I don't shoot M glass wider than 28mm.... I'm trying the S5 to see whether it works well enough to get rid of my M10-P. Makes sense to invest in glass, not (digital) bodies.
