Hi,
I've had a good search around the forums and lots of trial and error with the actual system based on it, but still can't solve this specific problem of multiple flashes firing sporadically.
I have a photogrammetry rig set up, where you capture numerous photos to create super high detailed 3D head models. Working well but the flash set up is causing headaches!
The setup is as follows.
There are 48 Nikon D3300s each with a Yongnuo RF603ii wireless trigger on the hotshoe
There are 8 flashes: YN560 - iv
All cameras are being triggered using Yongnuo RF603ii wireless triggers on the cameras with one additional unit as the 'master' trigger
Flashes are being triggered through the same 'master' trigger via a main controller - Yongnuo YN560-TX. The controller sits on a wireless trigger that itself sits on one of the hot shoes of the camera
Flashes are powered externally and cycle fine
All triggers and flashes are on the same channel (1) so dip switches set in the units and channel 1 selected on flash and main controller
I've been mostly testing with flashes at full power today but have seen the same problem with them at 1/2 power (next set of tests will look at lower power)
I've tried various speeds within the sync range and anything from 1/200 to 1/5 can still produce sporadic results where some flashes are lit and some not, or the camera will miss the flash completely resulting in a dark frame, or all flashes light, doesn't seem to be a pattern
I am trawling through the minutae of the somewhat cryptic user manuals, but have tried most things I can think of and hoping someone has some new ideas, as there seems to be some very knowledgable people on these forums talking about these makes/models.
Is it possible that the system is just too much? There are 48 cameras being triggered and 8 flashes. It is a thing of beauty when it works but need it be fully reliable.
Any help very welcome, and if I've missed anything in the description let me know. It makes sense to me but perhaps haven't described it well.
Thank you!
Ian
Thank you!
Ian
