If I'm at 35mm (APS-C) shooting a subject at 1000m with the closest foreground at 500m
I assume you mean the closest
significant object you want to be sharp. If you hold the camera horizontal at eye level (about 1.5m above ground) then the 35mm field of view will capture everything at ground level from 6.5m away from the camera.
and the furthest background at 2000m the scene should fall between the near/far plane of any aperture according to the DoF table.
Hyperfocal distance (HFD) is a useful concept (note I say concept - it isn't a better way of working than any other). It has two properties: if you focus
at infinity the nearest end of DOF is
at HFD; if you focus
at HFD the near end of DOF is at
half HFD and the far end is at infinity.
Look at your DOF calculator and you'll see that your camera-lens gives HFD about 21m at f/2.8. So if you focused there you'd still get your 2000m distance in the DOF and your 50mm distance; but the very closest things between the 6.5m I calculated above and 21m would be softened by being outside the DOF.
As I say, I'm not advocating the general use of HFD - in your case it's better to do what you say and focus on the critical features - but it does give an idea of how much or how little flexibility you get at different settings. I looked at this and by pure chance I picked 300mm to get a restricted field of view of that distant landscape and HFD calculates at 1000m - so DOF would run from exactly your 500m out to infinity, capturing 2000m on the way.
I know on my lenses that F8 is considered the sharpest
You can get details of lens resolution from sites like this
https://www.opticallimits.com/ https://www.ephotozine.com/
Here's my 35mm lens from OpticalLimits. You'll see its central resolution peaks at f/5.6 while edge sharpness peaks a bit later at f/8. This is typical of all lenses. Any drop from peak resolution exaggerates the out-of-focus blur that causes DOF, which is one of many reasons why DOF calculations are never better than a guide. Some lenses are pretty soft at the edges; with those the near end of DOF can be pushed away from what the calculations say.
For my lens the drop from f/5.6 at centre is more significant than the gain from f/5.6 to f/8 at edge so I always use f/5.6 for landscapes if possible. It's worth looking at your own lenses to do a similar equation.
and F11 is where diffraction starts to kick in
Strictly speaking diffraction is always present. It depends on how small the aperture is. At wide apertures it's very little but aberrations are significant; stopping down reduces aberrations and increase diffraction. The sweet spot is where they balance; after that diffraction doesn't "cut in", it just gets progressively more severe.
but is there any difference between using F8 and using a lower F stop like F2.8 to shoot the same scene - apart from letting me have a higher shutter speed?
See above. For my lens centre resolution at f/2.8 beats edge resolution at f/8 so it won't be disastrous; but the whole picture will be slightly softer even though it is all still within DOF. Knowing my own gear I'd happily go to f/2.8 for night scenes but only when forced.
Would there be more of a drop off in sharpness in the foreground/background using a wider aperture? Would there be a drop in sharpness of the subject?
Yes - see above. DOF is what appears "acceptably" sharp. Among other things this depends on the size of your image (screen or print) and how close you view it; and, importantly, how good your eyes are. At normal size and distance most things would look just the same because your eyes wouldn't be able to detect the difference. But if you have exceptionally sharp vision, or you print large or if you examine your photos in great detail you'd probably see a slight overall softening.
Oh, and at the extremes the difference would be more
noticeable on a camera with a higher MP sensor.
Gerry
________________________________________________________________________
I'm happy for anyone to edit any of my photos and display the results
_________________________________________________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
[email protected]
