Velocity of Sound
Hi everyone,
I used to enjoy culling my photos; it was a nice way to relive the experience, enjoy what came out, and reflect on it. But now I am a parent to two small children, who are also my main photo subjects these days. It means less discipline with the shutter button (trying to get that perfect moment... and children still strike me as being photographically unpredictable) and less time for photo editing, leading to nightmare scenarios in which I'm loading photos onto my computer and sorting through 2,000-3,000 photos in one go.
I want some aid to speed things up.
I'm currently using Capture One, and my general process involves manually sorting through photos, loading those from a sequence on screen to compare and try to discard those duplicates that are imperfect, choosing photos I really like for possible editing, and then either editing or leaving behind from that selection.
I used to use Apple Aperture, which - as I recall - would group similar photos (or at least, bracketed shots), which made going through them a bit easier. It's not a ton of time to manually find the start and end of the bracket, but it does add up...
I've been in search of some software assistance, and wanted to both solicit advice from what others are doing, and also share my findings. Because now there are a few programs out there that can help with this process.
First, Photo Sweeper X - at $10, it's the cheapest and probably the simplest. It's meant more for finding duplicate photos, but can also find similars and group them together. Performance seems fair, but even on its loosest setting it seems to split some similar photos into multiple groupings. It's also seemingly limited to viewing photos that macOS can view in Finder, and unfortunately for me, one of my cameras doesn't support that (compressed RAW).
Second, Optyx. Priced at $100, it's a lot more expensive but tries to do more. It has auto-grouping, similar to Photo Sweeper; like Photo Sweeper, even at its loosest setting it still seems to split photos into more groups than they should be. It goes a bit farther in automating the culling process by allowing you to designate some parameters, and then using artificial intelligence to try and rate/rank photos within groups. It's purely optional, and at this time I didn't feel it was reliable.
Third, AfterShoot. Currently in beta, it tries to fully automate the culling process, assigning tags or ratings to photos based on identified criteria. This seems like it should be a rather intensive task, and I'd say I was surprised by the speed with which it did all of this. Unfortunately, it also didn't seem particularly reliable.
While I like the idea of software being able to point out photos with blur or closing/closed eyes, at this point in time it doesn't seem to be able to do it reliably. I'm sure we'll get there some day, but for now, I think software that could group similars would go a long way toward making my life a bit easier. Maybe I need to play with Optyx and Photo Sweeper a bit more...
So, what are the rest of you doing? Any particular recommendations? Even if you're not using a software aid, I wouldn't mind hearing about workflows that help you to get through the process a bit faster and remain motivated.
