Large format loupe recommendation?
Jhensen
New member
I am moving up from an RZ67 and waiting on my first 4x5 camera (Intrepid) For landscape use. I have about 8 weeks to build out my kit before it arrives and the last thing I am having trouble finding good information on is a focusing loupe. I am hoping I can leverage some of the experience on here to determine:
1) What magnification is recommended? I’ve heard 6x.
2) Does the brand/manufacturer make significant difference?
3) For any recommendations, are they readily available new or used?
If it helps, I am looking for something reasonably priced (ideally no more than $150) and will be using glass between f/5.6 to f9. I am also young with naturally very good eyesight.
Hello jhensen!
This may not be a proper answer to your question, but still...
When I need a loupe I use a Rokkor 50mm 1,4 or 1,2 and look through it from the reverse end. I am not sure how many times enlargement I get, but it is more than useful to me. I use this "loupe" when I need to find exact sharpness on my Fuji GX680's focus screen.
Regards
When I was in my 20's and 30's I hardly ever used a loupe, you should be fine with the f5.6 lenses, I was good up to a 10 inch f6.3 Commercial Ektar. F9 may be a little dim, I currently have an f8 Super Angulon, and I use a Schneider Loupe with it.
Although it seems to no longer be in production, I would recommend a Wista loupe.
These are harder to find in the digital era. I used to use a Schneider 4x lupe which was adjustable focus. (That may have been just diopter type thing.) Also Toyo used to make one that was fixed focus.
I just found a used SK one from B&H for $80. On its way right now.
This is B&H photo
This is B&H photo
I think if you go with much more magnification than 4x you run the risk of having your ground glass etching get in the way of focusing.
Ross Attix
This is the one I finally settled on after years of trying various other options.
Made in Wetzlar, Germany right next to Leica. Made by EMO and sold by Foto-Care.( most likely out of business! )
