I couldn't really find a section that was fitting for this topic, but ended up choosing this one since the people into adapting old lenses would probably be the most likely to know about re-greasing old lens helicoids.
So, can anyone recommend to me a pro-grade grease for re-greasing lenses that will maintain its consistency at high/low temperatures and last decades without hazing internal lens surfaces or getting on aperture blades?
The grease is have used often is (#10 & #30) from micro-tools.com(it can also bought it at japan-hobby-tool.com for less $, it's also on eBay) they are silicone based, #10 is very light(note the silicone oil can separate out), it works a whole lot better than most greases I've tried, effort is very much reduced especially if the helicoid threads have a fine pitch. Here are some old links:
http://www.micro-tools.com/store/P-HG-10/Grease-Helical-10-Light-8ml.aspx
http://www.japan-hobby-tool.com/cart/syouhin.php?cat=00000010&no=00000048
I can't seem to find any other listings on eBay other than this one which is expensive. If anyone finds another listing for less $$ please post it
https://www.ebay.com/itm/Japan-hobb...ool-Herical-Grease-Japan-JHT9110/143660108848
An update on grease I use, I use, I mostly use the #10, I find the #30 to have too much drag, lately there are a few lenses that I have had some issues with the grease getting into the aperture mech because the helicoid is so close, for these and a few other lenses, I have been using Helimax XP, it's in-between the #10 & #30 greases for drag/resistance feel of the focus ring, it's best for helicoids that have a short path to the aperture mechanism or optics, it doesn't separate out like other greases, definitely recommended for the first time DIYer. It's available on eBay.
https://www.ebay.com/itm/HELIMAX-XP-Camera-Telescope-Optical-Instrument-Focusing-Helicoid-Grease-w-PTFE/123651606955
I also came across some new grease I've not seen before, looks like it may be similar to the Helimax XP, if anyone has used it, please post your thoughts on it.
https://www.ebay.com/itm/Helicoid-Grease-Telescope-Camera-Optical-Instrument-w-PTFE-NEW/184108250538
https://www.ebay.com/itm/Helicoid-U...al-Instrument-w-Krytox-PTFE-28GR/184232664894
To apply the grease, I use a small artist brush (2-3mm) and brush the grease on in a very thin uniform layer, it doesn't take much, use too much and the excess will be pushed out and will be free to go where you don't want it.
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
