No, completely different technique. X-T3 does not have IBIS so clean the X-T3 sensor with the camera off. I would take the battery out too in order to avoid turning the camera on by accident during the sensor cleaning.A little off topic as per the OP's question, but is this the same for the X-T3 ? I'm a new Fuji user.
This is what I do in my GFX 100 and what I bet you do on the XT-4.
Sensor Cleaning:
1. Turn Camera on. (The Sensor is cleaned with power on.)
2. Set IS mode to Off. (This pulls the sensor into lock mode.)
3. Switch the shutter to ES. (So the shutter won't accidently trip.)
4. Turn "Shoot without Lens" to Off. (So the shutter won't trip w the lens off. Default is Off, but you may have turned it on to shoot adapted lenses.)
5. Turn Power Saving Mode to Off (So the camera will not power off after two minutes.)
Well, I have cleaned my XH-1 and GFX 100 sensors a lot. I get them dirty because I change lenses a lot.Thanks for this!This is what I do in my GFX 100 and what I bet you do on the XT-4.
Sensor Cleaning:
Wouldn’t it be nice if there was a “Sensor Cleaning Mode” menu option that did all this at once?
An X-T4 sensor cleaning isn't any different than wet cleaning any other sensor with IBIS. The sensor will move a little when wiping unless the camera is turned on and IBIS is deactivated.So lots of advice here from folks who haven't done a wet cleaning on a T4. Is there anyone out there who has successfully followed the recipes suggested above on a T4?
I appreciate that. Of course, how long one goes between any cleanings, blowing or otherwise, can matter too. It's pollen that gives the most trouble - except for that one time I coughed a glob of mucus onto the sensor during a cleaning [g].Bob,
Thank you. That was very useful. I agree that wet cleaning is a last resort as the rocket often solves the problem. I abandoned the sticky sticks as I found them not to be a reliable substitute when wet cleaning was needed.
Wet cleaning is not a last resort. It is routine if you shoot like I do.Bob,
[eye roll] Yea, your field practices are rather well known by now, Greg.Wet cleaning is not a last resort. It is routine if you shoot like I do.Bob,
I hear you. I don't clean my sensors routinely. That is probably the wrong word. I just am not afraid to clean the sensor. It is not big deal. I have cleaned my GFX 1oo sensor maybe 4 times. 50r maybe 4 times. XH-1 maybe 8 or 10 times back when I was shooting it.[eye roll] Yea, your field practices are rather well known by now, Greg.Wet cleaning is not a last resort. It is routine if you shoot like I do.Bob,
But for typical amateurs & enthusiasts, circumspect with routine blowing, wet cleaning doesn't have to be a routine practiced more than once a week or once a month, if that much.
Fair enough - similarly, that's how I got wet cleaning practice on prior cameras, not paying it much mind until it was hard to ignore and only a wet cleaning would do.I hear you. I don't clean my sensors routinely. That is probably the wrong word. I just am not afraid to clean the sensor. It is not big deal. I have cleaned my GFX 1oo sensor maybe 4 times. 50r maybe 4 times. XH-1 maybe 8 or 10 times back when I was shooting it.[eye roll] Yea, your field practices are rather well known by now, Greg.Wet cleaning is not a last resort. It is routine if you shoot like I do.Bob,
