Blue Egypt
Member
Hi all,
So, I finally entered the world of Panasonic/MFT for my video work a few months ago by purchasing a used GH4. This already came with the GH4/GH3 cage by SmallRig, which is SmallRig item number 1585, I believe. It came with the HDMI cable clamp (1693) as well.
I want to take advantage of what I already have now, and maybe build something around this cage that would be more of a handheld/"run & gun" setup. (I plan on using the GH4 on a gimbal in other cases.) I think what I'm after is a little help and inspiration as to what other SmallRig components I could benefit from and how I'd accessorize such a setup. I find some of the SmallRig portfolio a little hard to navigate. Most of the items that would make up the final setup could then probably be re-used, e.g. if I ever upgrade to the GH5 (or future "GH6") or maybe the BMPCC4K.
So, here are some ideas I've picked up so far and what a potential rig could look like. Ideas and criticism appreciated:
The cage being the basis for my rig features an off-center cold shoe, which I will most likely be using to mount my Rode VideoMicro. One further SmallRig piece that is most definitely going to be part of the final setup is the a top handle (e.g. 1638). This can be used to carry the rig, and will probably also be good for some nice underslung shots. The top of the handle can also mount an external video monitor, which I will likely purchase and which will likely be part of this setup. Depending on what comes with the monitor, an additional SmallRig gadget (like the multi-functional ball head 1875) may come in handy here.
One part I'm still struggling with a bit is whether and how there should be any kind of side handle. I've seen setups with side handles being attached to both sides of the cage. Not sure whether that would even be a good idea. If I go for any side handle, I'd probably want it on the left-hand side of the cage, while still grabbing and controlling the actual camera with my right hand. One of these items may qualify:
SmallRig Aluminum Universal Side Handle HSS2425
SmallRig Universal Wooden Side Handle 2093
So, that's what I came up with so far. I think this could already qualify as a "complete" run & gun setup in some people's book. Am I missing out on anything obvious? I guess, due to the standardized threads, I could even be shopping outside of the SmallRig world? And if I ever decided that shoulder-supported shooting is the way to go, I could throw that very same setup on a 15mm rail support system (possibly via a quick release plate/dovetail) and keep building it from there?
Thanks in advance!
Thanks in advance!
