Ive used the Stackshot, WeMacro and MJKZZ older type rails & controllers. The Stackshot is the most versatile and the WeMacro best value. Never used the MJKZZ rail because at that time the controller didn't support a Mac, later a controller was offered which didn't require a computer and works well, but the rails were bypassed because better rails were available. All the rails can be operated with different controllers if you prepare a proper interface cable to the stepper motor (they all use 4 wire steppers), and setup the proper motor parameters.
Later developed custom rails based on the THK KR20, 15 and 26 surplus linear rails. These are precision devices and can be operated with various controllers, including a set of custom developed controllers based upon the Trinamic chips that offer exceptional performance.
Eventually this evolved into Stack & Stitch setups, below shows some of the THK rails and custom controllers. Much has been posted on these developments over at the mentioned Photomacrography site.
https://www.dpreview.com/forums/thread/4342999
Best,
Horizontal setup on modded WeMacro Stand and THK KR20 focus rail
Vertical setup shown in back.
