Seems like tonight we will have a good opportunity to shoot some of the Starlink satellites over here.
Can anyone suggest a fool-proof setup to me? I’m in no way experienced in astrophotography and won’t have the time for much preparation. I’ll be shooting with a Nikon D810 and one of the f/2.8 zooms (14-24, 24-70 or 70-200). No 1.4 prime available at present.
Intended shot: Not just the satellites but some foreground as well, satellites shall be captured as single objects and not combined to a light trail.
What settings will work as far as aperture, shutter speed and ISO are concerned?
Single shot vs. several shots (to be stacked)?
Thank you very much in advance!
Btw, before you ask, I’m only after capturing the special scene although I don’t like Mr. Musk’s project of the 12.000 night sky polluters …
You can use a site like
n2yo.com to find pass times and locations, then use that information to set up your gear in the proper direction.
Thanks for your answer.
As for the Starlink satellites one can use the site
https://findstarlink.com/
There you enter the intended coordinates and find visible times (+/- few minuntes) and the exakt direction (after clicking "details") as a result—works perfect as I could notice yesterday.
I'm really not sure what you meant by "captured as single objects and not combined to a light trail." You need to be more specific as that can be interpreted multiple ways. I assume you meant you don't want to create a star trails image. But I’m not sure exactly what you meant.
If the shutter speed is too slow one cannot identify the single satellites out of the current SpaceX's satellite swarm. Say I shoot 1 sec I'll receive a light trail only.
All satellite images taken with your listed equipment will likely show trailing for the satellites because they move across the sky fairly quickly. You could for example take a wide angle shot using 24mm FL, set the shutter speed to 8 sec, and the result would be stars that look like points of light (no noticeable trailing) but the satellites would most likely have trails because they are moving across the sky fairly quickly. A series of shots that are stacked would create star trails and elongate the satellite trails. The only way to prevent the stars from trailing when stacking multiple images would be to either track the stars with a special mount that I doubt you would have or to use alignment/stacking software. Both are too complicated to go into in this post.
You're completely right of course—no such equipment here. So my idea has been that maybe taking two shots could work somehow:
First shot exposed for capturing the satellites as single objects, no light trails.
Second shot must be taken directly after the first one and has to be exposed for the foreground.
Maye a third shot for the sky?
Then put both resp. all three of the images to PS and combine them appropriate.
Do you think this strategy could work? Switching shutter speed and ISO value would take say 5 sec before the second shot can be taken. So not so much movement of stars during that time.
If this seems to be worth an attempt then my question is: At f/2.8 what shutter speed / ISO combination can be assumed to take a sharp shot of the satellites?
Since you probably will be shooting from a stationary tripod mount (no star tracking capability), then decide which FL you want to shoot at. None of your listed lenses will show much more than a point of light or light streak as they have FLs that are too small to show any satellite detail. So I would select the FL that gives you the FoV (field of view) you want, and divide 200 by that FL to get the shutter speed. So for example, 200 / 24mm = 8 sec shutter speed. Set the ISO to 800. You will need to take test shots to set the aperture to a level that will yield decent images. Look at my link in my signature below to learn how to focus on stars.
Thanks. That's about how I've done it in my first try yesterday. "About" means your step 6 is a good addition I didn't regard so far.
You will need to know where in the sky the satellites will pass by, and set your camera to point at that location. You will need to know when they will pass by so you can start shooting. I would suggest using an intervalometer to take a series of shots starting just prior to the satellites pass and extending to just after the pass is finished.
Knowing where the satellite swarm comes along seems to be the easiest part of the task.
If you have never taken night sky photos before, then you will likely get frustrated. This takes a LOT of practice. Don't give up though, keep practicing and eventually you will have the necessary skills to capture what you want.
Frustration is what I faced yesterday
And that let me remember that I got really good advice over here at dpr in some ealier times already.
