Hello dear photographers.
Half year ago I realized focus issues on my Rokinon 8mm F3.5 CS II (Canon) lens. Upon searching this issue came up with manuals in calibration fix. I followed them and got the lens back to the sharpest setting.
Now strangely I face same problem but with serious state. The calibration I did was 5-6 month ago and when I used lens 3 months ago - it was alright. While checking the lens now I surprised to see that it got totally misaligned suddenly. Immediately started the calibration again but for my surprise the problem is beyond the calibration range.
While reaching the end of the far/infinity focus the barrel already reached to the base and it was still unfocused at 50cm distance. Checked the actual focus sharpness at infinity position - it showed focus to be sharp at 10-12cm distance. Can't turn the ring anymore as it reached the end. I have no idea how the lens may come up to this point with almost no use during months. On my return trip carried the lens in semi soft/hard carrying case in my checked suitcase. It was placed inside backpack and was secure to not be loose in the luggage.
I felt like maybe the barrel was pressed thus reached the end of rotation unusually - so I tried to check whether can it be pulled back a bit - no way - it was sturdy.
Shortly I can't turn the focus ring far than that point and the lens has max 10-12 cm focusing distance now. I use LiveView in Canon 70D to check the focus. Do you have an idea what could happen and how can it be fixed?
Wish you be safe.
Wish you be safe.
