What a painful experience!Peak Design. The reasons in my experience are security and convenience. Particularly with L bracket use the PD can be configured several different ways. Also much easier to use with tripod than years ago experience with BR.
I did have BR carabiner failure years back, D700 with 24-70 fell off. (Carabiner latch rather than loosened connector). I know it has been revised several times since and security tethers are now offered as well, but one failure and dislike of the swinging pendulum effect was enough for me. Fortunately the days of a half dozen active failure threads are long past and it is now more an issue of personal preference.
The loop with the red connector button is easy to mount onto the triangle. Push the end through, then over the red connector end, and pull it tight. I occasionally move it to a different connection point during a session, and that's fast and easy. The loop cord itself is strong and has a black woven cover over a white core, so it's easy to see if it's getting worn. No wear at all so far.Thanks for all the answers - much appreciated.
2 questions re: the Peak Design -
1. Can it be attached easily to the triangles on the side of the Z7?
2. Would you recommend the Slide or the Slide Lite for the Z7?
Thanks!
Vic
fpgear.com
