I found a comparison of Canon's HEIC files compared to JPEG, but I'm interested in how they compare to RAW, in quality and editing flexibility as well as filesize. Are there any 1DXIII owners who have evaluated this? I assume things like WB, Sharpness, Picture Styles, etc, will be baked in as with JPEGs?
(Although I'm unlikely to get a 1DXIII myself (not enough megapixels for my needs), I'm interested in the upcoming R5, and expect it will have HEIC. I'm a dedicated RAW shooter, even though I do events with thousands of photos in a weekend, and a big jump in megapixels would bog down my workflow, but I'm wondering what penalties there would be for using HEIC to shrink the filesizes.)
Bump.
Picking on this as the R5/R6 world probably will support 10-bit HEIF output as well, and with Adobe's stubbornness to pay the ransom to Canon for a color match, HEIF output makes for a good alternative to doing any RAW processing as now even Apple Photos can tweak with better results than a JPEG. Between RF lenses having profile data on-lens, so correctional data is available instantly, DLO processing and Canon's pretty accurate AWB these days, if, you add 10-bit latitude to the mix? This could be pretty interesting.
This becomes a subject unto itself... HEIF formats largely come from iPhones, small sensors. Outside of the 1DX Mark III, I don't know this has been done. Likewise, I don't know how well post processors aside from Apple's Photos, handle adjustments to HEIFs.
I would love if someone with a 1Dx MKIII could share some heif files to test. I think they can be edited in Lightroom right?
HEIF has been supported by Adobe since 2018. Should behave no different than an iPhone picture with the same benefits and limitation, except obviously a-lot more oomph vs an HEIF out of an iPhone!
The benefits is 10-bit (vs 8-bit JPEG) and no need for color matching or lens correction data.
The limitations of lack of WB correction, sharpness and noise reduction "baked in" and only 10-bit (vs 14 or 16 bit RAW files). So you'd need to fine tune your noise reduction and sharpness in camera obviously, but I understand the 1DX III has more customizability in regards to sharpness and better noise reduction so that's not necessarily that bad of a thing.
And I think in the heif format can go higher in bits, so the differences with raw will minimize further. I think the future is there, I don’t want to be dealing with bad color profiles in third party software if I like the brand color signature as starting point for small edits in most of the pictures I take when I just want minor edits etc, and DPP is too slow...
having that kind of file with higher dynamic range than the jpg, Canon color science, and also in camera sharpening and noise reduction (that gives more pleasing results than Lightroom in general...) is a win win...
Yes to all the above.
The catch: Canon's flavor of HEIF presently is 10-bit, even though the format supports more than that.
10-bit is a leapfrog over 8-bit, but yes, 12 or 14-bit would be better still; more like an efficiently compressed TIFF. 10-bit HEIF gets us fairly close though to a TIFF in terms of practical use. RAW or CRAW still should be captured alongside for "troublesome" shots where drop is needed for squeezing out of the image, but HEIF should be able to address a vast amount of post processing needs when combined with Canon's other technologies (AWB with AWB-W support, newer sharpness and NR engines, newer CFA, DLO and ALO in camera with multiple strengths and configurations).
Here's a quote lifted straight from Canon's document on R5 improvements regarding the matter:
"Both EOS R5 and EOS R6 are capable of recording [HDR-PQ Shooting] still images in HEIF file format. These 10-bit files feature broader tonal range and bit depth in-comparison to 8-bit JPEG image, allowing for even more highlight detail to be captured, when displayed on HDR-compliant monitors or via HDR printing workflow."
