Canon T2I still using it with success.
Started Feb 16, 2020 | Discussions
jerelee Regular Member • Posts: 455
I am still using it and doing very well with it, I know I'm not alone in this. How many out here are still using theirs and still enjoying the quality photos they are getting from it. I have newer cameras, but still go back to T2I quite often and enjoy using it.
 jerelee's gear list:jerelee's gear list
Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Canon EF 70-300mm f/4-5.6 IS USM Canon EF-M 18-55mm f/3.5-5.6 IS STM Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Canon EF 50mm F1.8 STM +1 more
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4)
Agapeman Regular Member • Posts: 108
Re: Canon T2I still using it with success.
I am about to pick up one of these from a close friend who hardly used his. It comes with the two kit lenses and a couple others as well and many extras. I am looking forward to adding this to my G12 and G3X cameras. I read a few reviews on this camera and it will fill my needs perfectly. No need to have the latest and greatest for me. Keep on using yours as long as it works for you.
 Agapeman's gear list:Agapeman's gear list
Canon PowerShot G12 Canon G3 X Canon EOS 550D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
Digirame Forum Pro • Posts: 41,858
I had been using mine for years, until a couple of weeks ago.  I finally upgraded to a Canon T7i (800D) camera (my second one).
Here's one of the last times I used it in February of this year, when I went to Salem, Oregon.  I may use it some more.  The Canon T7i (800D) has so many more advantages in low light conditions.  But if there's sufficient light, the older camera should be fine.
karl mohr Senior Member • Posts: 1,678
I had one, bought it brand new in January of 2011.  Still a fine camera.  I finally sold it to a lady in my club and she absolutely loves it.
 karl mohr's gear list:karl mohr's gear list
Canon 6D Mark II Canon EOS 60D Canon EOS 80D Canon EF 17-40mm f/4.0L USM Canon EF-S 55-250mm f/4-5.6 IS +3 more
OP jerelee Regular Member • Posts: 455
Any more out there I'm sure there is?
MRphotog Regular Member • Posts: 249
Still have mine. Use it mostly in good light with a 18-200 permanently attached. Been thinking about getting a 35 or 50 mm equivalent prime to make it a little easier to carry around and for lower light situations. It still produces great images and 18 mp is fine for most anything I shoot with it.
 MRphotog's gear list:MRphotog's gear list
Canon PowerShot S3 IS Canon PowerShot S95 Canon ELPH 300 HS Sony RX100 Fujifilm X100S +41 more
Re: Canon T2i (550D)...today's pictures
Today, in full sunshine I used two Canon T2i (550D) cameras and one Canon T3i (600D) camera. Tomorrow I'm planning to go to a people event. It is supposed to be cloudy at least part of the time. I'll use the two Canon T7i (800D) cameras.
Here's what I got today with the Canon T2i (550D) cameras.
Photo No. 1
Photo No. 2
Photo No. 3
That's proof of the pudding excellent shots especially the ducks. Duck shot has excellent detail.
I have never had a problem with a low light photograph from my T2I. Please explain why your new Canon is much easier to capture a low light photo with than the T2I. I would think the lens would have a lot to do with it and not so much the camera. I have looked at some of my photo enlargements taken with my old 10D Canon from several years ago they were team photos, extremely large, and they look great. Remember the 10D was a 6 mp camera also!
It depends on the definition of low light.
Here's one example.
I could make side by side tests if you would like; please let me know.
Another example.... I had to have enough shutter speed to freeze the action. Plus I wanted ample depth of field. Now, these cameras are not designed to take pictures in the pitch black dark, but they do well enough when it's almost dark. I could not take decent pictures at ISO6400 with the Canon T2i (550D) camera in low light conditions like this.
Here's another one at ISO10000.
And ISO10000 again....
Here we see a photo at ISO12800. You got to have enough shutter speed for ice skaters without using a flash. At sports events they don't want photographers using the flash indoors (at least where I have taken pictures). This is with a kit lens. I suppose the image quality would be a little better with more expensive glass.
Another advantage I like with the Canon T7i (800D) camera is this.
I can use manual mode with auto ISO and set the aperture and shutter speed like the Canon T2i (550D) camera. But I can also adjust the exposure compensation. That was huge for me. And now that the higher ISO levels are better, I don't mind if they go up to ISO12800 (if it's important that I have that aperture and shutter speed).
Also I like the extra megapixels and the nine center AF points. But still the Canon T2i (550D) camera is a great camera for its generation. That's why I had used it as long as early of this year.
There is a workaround for auto ISO and using exposure compensation, although for the Canon T2i (550D) camera. I could use Av mode, auto ISO and exposure compensation. I would then choose the aperture. The shutter speed would be dependent on the focal length of the lens. You could test it to see; it's been a long time since I've used it that way. With that combination, the 55mm focal length would produce either 1/80th or 1/100th of a second shutter speed.
Here's another one at ISO6400 from the Canon T7i (800D) camera on a rainy day.
Thanks so much for the information, I appreciate it.
Cliffo6 New Member • Posts: 11
I have owned one since 2011 and it still works fine.  However, I rarely use it any more since I prefer Canon SLRs with the articulating touch screen.
