To my knowledge, the 45-100 has not been released.Would anyone please compare these lenses? After seeing results of the 110 vs. the 100-200, I'm not excited about Fuji's zoom lenses.
Is the 45-100 much better? Is it much sharper than the 100-200?
You're right. I just saw on B&H that it has a price and a page, so I assumed it was released -- but it's not.To my knowledge, the 45-100 has not been released.Would anyone please compare these lenses? After seeing results of the 110 vs. the 100-200, I'm not excited about Fuji's zoom lenses.
While the 32-64 seemed sharper than many of the primes I had used before switching to Fuji, I do not believe it is sharper than the Fuji primes within its range (although Fuji posted an mtf chart that depicted the zoom at 64mm being near equal to the 63 prime).
I do not expect the 45-100 to be sharper than the 45, 63, 110 primes or the upcoming 80mm prime but that is not the primary purpose of a zoom.
As for your question, I hope it is sharper. I always hope a company releases a sharper lens, not to say that I believe the 100-200 is a dog.
On Kasson's website, I saw a comparison using the GFX50 with the 110-200 vs. the Sonnar 135 with a full frame (FF) body. The FF image was quite a bit sharper, which tells me that the same lens with the GFX100 probably wouldn't be a big upgrade, for my purposes (yet it is a lot more expensive and heavier.)I agree that the 100-200 is anything but a "dog". It's interesting that Fujifilm, even early in the product lifecycle, released three lenses in the focal length range between 100 and 120 mm.
They did this out of recognition, I think, that there are areas of specialization in requirements for lenses at a given focal length. Any lens represents design decisions attempting to arrive at a combination of characteristics that meet use-case requirements. Different areas of specialty come with different aspects of compromise; you pick the set of compromises that best fit the requirements you're dealing with.
What's remarkable to me about Fujifilm is their willingness to acknowledge designs tradeoffs and to release lenses with such strengths in each lens's area of specialty.
In the 100 to 120 mm neighborhood they designed and released a high speed bokeh specialist (the 110), a macro specialist (the 120) with OIS, and a lens specializing in, well, general purpose flexibility (the 100-200), with OIS, at comparatively light carrying weight.
If your requirements call for dreamy, creamy bokeh, the 110 is a jewel. If you need to be able to produce near-macro work, neither the 110 nor the 100-200 will produce the best results. If your requirements call for flexibility to enable choosing between multiple focal lengths for a given situation without switching lenses, you reach for the 100-200.
Our British friends have an apt phrase, "horses for courses".
I think it's wonderful, and maybe a little surprising, and genuinely reassuring, that Fujifilm produces this range of offerings. They're serious about enabling photographers to make fine matches between their requirements and lenses to meet them.
It means one can decide which lens to reach for that best matches a given situation's requirements.
I'm looking forward to the arrival of the 45-100. If its performance is comparable to that of the rest of the lineup it's going to be an excellent "walking around" lens.
These are great days! We have amazing tools available to us!
Here's that post:On Kasson's website, I saw a comparison using the GFX50 with the 110-200 vs. the Sonnar 135 with a full frame (FF) body. The FF image was quite a bit sharper, which tells me that the same lens with the GFX100 probably wouldn't be a big upgrade, for my purposes (yet it is a lot more expensive and heavier.)
Hi Jim;Here's that post:On Kasson's website, I saw a comparison using the GFX50 with the 110-200 vs. the Sonnar 135 with a full frame (FF) body. The FF image was quite a bit sharper, which tells me that the same lens with the GFX100 probably wouldn't be a big upgrade, for my purposes (yet it is a lot more expensive and heavier.)
https://blog.kasson.com/gfx-50s/fuj...n-70-200-2-8e-apo-sonnar-135-on-z7-revisited/
Jim
The GFX 50x has a 50% effective fill factor, so it's got a huge advantage over a 100% fill factor FF camera like the D810 in Imatest slanted edge testing.Hi Jim;Here's that post:On Kasson's website, I saw a comparison using the GFX50 with the 110-200 vs. the Sonnar 135 with a full frame (FF) body. The FF image was quite a bit sharper, which tells me that the same lens with the GFX100 probably wouldn't be a big upgrade, for my purposes (yet it is a lot more expensive and heavier.)
Jim
What are your thought on the discrepancy between your comparison of the 100-200 vs. Nikon 70-200 E and PCMAG's Imatest results in their review of each?
I'm referring to these two reviews:
https://uk.pcmag.com/lenses/120179/fujifilm-fujinon-gf-100-200mm-f56-r-lm-ois-wr
https://uk.pcmag.com/lenses/88641/nikon-af-s-nikkor-70-200mm-f28e-fl-ed-vr
To summarize the relevant sections, they measure center-weighted average score in Imatest:
Nikon at 135mm f/4 resolves 3,593 lines with a 36MP sensor
GF 100-200 was not tested at 186mm, but scores
~4,937 lines at 150mm f/5.6 and 4,693 lines at 200mm f/5.6, with a 50MP sensor.
That sounds a lot like hypothesis a) among the ones I listed, but I'm not sure. Can you explain what fill factor is? A google search on "Imatest fill factor" yielded no obviously relevant results.The GFX 50x has a 50% effective fill factor, so it's got a huge advantage over a 100% fill factor FF camera like the D810 in Imatest slanted edge testing.Hi Jim;[snipped]
Jim
It's how much of the light falling the square one pixel-width wide and tall is used for imaging. As the fill factor goes down, the MTF goes up, but aliasing gets worse.That sounds a lot like hypothesis a) among the ones I listed, but I'm not sure. Can you explain what fill factor is? A google search on "Imatest fill factor" yielded no obviously relevant results.The GFX 50x has a 50% effective fill factor, so it's got a huge advantage over a 100% fill factor FF camera like the D810 in Imatest slanted edge testing.Hi Jim;[snipped]
Jim
Some more reading before you give up on the 100-200:OK, thanks for the information. Searching around a bit for more test results, I found more unfavorable experiences on its performance https://www.dpreview.com/forums/thread/4406955
Not that bad, but for such conservative specifications and premium price, it is really disappointing. I'm not buying a system without a good telezoom that is worth the investment, so this has really killed my interest in GFX for the near future. If I get the interest again, I will bring a test chart, laptop, SD card and trusty X-T2 with me to the store for two hours of pixel peeping before considering a purchase.
Right now I am leaning towards sticking with APS-C, picking up the excellent 50-140mm and eventually a 30+ MP camera for 'close enough' results at less weight, less cost and higher flexibility. I've seen comparisons of the 50-140mm significantly out-resolving the most popular Canon DSLR equivalent. The new RF and Nikon Z lenses are probably better still, but as expensive as the GFX.
Not sure what you mean by that. If it's zoom range, I agree. Do you mean it's not a constant aperture f/4 lens, like the 32-64? It would be a lot bigger and more expensive if it were.OK, thanks for the information. Searching around a bit for more test results, I found more unfavorable experiences on its performance https://www.dpreview.com/forums/thread/4406955
The price is quite low for an MF zoom with roughly those characteristics. I think that Fuji has excellent lens designers, and this lens was designed to size and price.and premium price,
Here's a side by side of the 110 vs the 100-200 both of which I shot with the GFX 50s. To me, the sharpest lens is self evident in this particular comparison.On Kasson's website, I saw a comparison using the GFX50 with the 110-200 vs. the Sonnar 135 with a full frame (FF) body. The FF image was quite a bit sharper, which tells me that the same lens with the GFX100 probably wouldn't be a big upgrade, for my purposes (yet it is a lot more expensive and heavier.)I agree that the 100-200 is anything but a "dog". It's interesting that Fujifilm, even early in the product lifecycle, released three lenses in the focal length range between 100 and 120 mm.
The 45-100 should be almost perfect for the style that I want to shoot; I may not need a second lens at all. If it's as sharp as the 32-64, I'd be happy. As for what I want to shoot: environmental portraits, to turn into make massive prints: I need high image quality, but not great bokeh.
And you did your test at the good end of the 100-200's focal length range...Here's a side by side of the 110 vs the 100-200 both of which I shot with the GFX 50s. To me, the sharpest lens is self evident in this particular comparison.
https://www.dpreview.com/forums/post/62669860
X-day is 27th February in Japan. It should be similar world-wide.You're right. I just saw on B&H that it has a price and a page, so I assumed it was released -- but it's not.To my knowledge, the 45-100 has not been released.Would anyone please compare these lenses? After seeing results of the 110 vs. the 100-200, I'm not excited about Fuji's zoom lenses.
Yes, I saw that the 32-64 is not as sharp as their primes. However, it was impressively close -- close enough for me.
Ya'll hurry up and buy it and let us know how it performs.X-day is 27th February in Japan. It should be similar world-wide.You're right. I just saw on B&H that it has a price and a page, so I assumed it was released -- but it's not.To my knowledge, the 45-100 has not been released.Would anyone please compare these lenses? After seeing results of the 110 vs. the 100-200, I'm not excited about Fuji's zoom lenses.
+1Ya'll hurry up and buy it and let us know how it performs.X-day is 27th February in Japan. It should be similar world-wide.You're right. I just saw on B&H that it has a price and a page, so I assumed it was released -- but it's not.To my knowledge, the 45-100 has not been released.Would anyone please compare these lenses? After seeing results of the 110 vs. the 100-200, I'm not excited about Fuji's zoom lenses.
Yes, I saw that the 32-64 is not as sharp as their primes. However, it was impressively close -- close enough for me.![]()
