How to avoid Nikon NX-D to create NKSC_PARAM sub-directory ??
  • Thread starter Thread starter JP Scherrer
  • Start date Start date
J
JP Scherrer
Guest
Hi ! Having used for yeeeaaars the old Nikon Capture NX-2, then only Photoshop's ACR, to process my NEF images, I had the curiosity to try the "newish" NX-D ! Definitely not as nice as the old one, but well...
Thing is, I always use Nikon ViewNX 2 and its great TRANSFER utility ! When I drop my CF-card in the card reader, it automatically opens and runs TRANSFER, which automatically creates a new sub-directory in my HD, downloads the files in it and opens Nikon ViewNX 2 !! Just GREAT !
The problem is that now, after having installed CNX-D, it changed the old TRANSFER for a new one, and now, it creates this damn NKSC_PARAM + one file per image ! I HAIT this and I don't want it !
Is there a way to avoid the software to create these useless directory and files ! ...or is there a way to get the OLD "TRANSFER" and have it running like it used to do ?
Thanks for your tips and suggestions !
J-P.
When you install NX-D and NXi it deletes the old software. You just re-install ViewNX2 after installing the new software and you're good to go. You can get the download from the Nikon website.
As far as the new directory is concerned it is the standard used by most photography software which creates a sidecar file during editing and applies the file when you convert it to jpg. This ensures the old NEF file is not destroyed.
As an aside I use Viewnx2 as my first pass jpeg editor as it preserves the original jpg by copying it into an originals folder. Viewnxi works the same as NX-D it creates a sidecar file even for jpegs..
OP: What he said.
The NKSC_PARAM directory is the location of the sidecar files which holds the development and other metadata data used in the RAW file edits. This means any RAW processing you do is stored in those file and is accessible via both Capture NX-D and View NX-i. View NX-I creates it, too. Those files are the record of the RAW edits you have done, and any time you open Capture NX-D or View NX-i, it opens those files up and displays them with the edits you already did. If you lose the .nksc file associated with a given RAW file, you're effectively starting over when you open the RAW.
After a recent trip, in an epic display of talent I somehow managed to delete the NKSC_PARAM directory for an entire portion of my vacation (and I failed to back it up. Genius, I know), which necessitated an imperial buttload of time to re-process all of the RAWs to match what I had done with the already-processed JPG--since some people wanted prints as opposed to web-ready downsampled images. Needless to say that was as fun as a pantful of piranha--and a reminder to back up more often, but I digress...
Unless you plan to hit your photos only once and then forget about processing/reprocessing, I'd recommend keeping that folder if you plant to keep using Capure NX-D and View NX-i.
The sidecar file subdirectory has nothing to do with the new Transfer. It's part of the workflow of NX-D and NX-i. Changes to raw files are no longer saved in the files themselves, they are saved to sidecar files in the subdirectory. Unless you never edit raw files, there is no way to avoid it.
That said, if you do all you file management (moving files around and such) in NX-i, you won't even see the sidecar folder and can forget that it exists.
Thanks ! That's what I did: as I definitely do not like NX-I, even though it accepts the D8xx RAW files, I deleted it and reinstalled ViewNX 2 !
Everything back to normal :-) !
You don't actually need to delete it both bits of software live happily together but as you won't be using nxi its not a problem either.
