abgestumpft
Forum Enthusiast
- Messages
- 436
- Reaction score
- 675
Hi,
I recently upgraded my PC to an AMD Ryzen 3700x with Win 10
Afterwards, when I was quickly scanning my Fotos with FastRawViewer the program was hanging (freezed) from time to time for several seconds. I did not see such behaviour e.g. when working with Lightroom / DXO / ... only with FastRawViewer.
First I thought its an application issue, but when I had Lightroom opened in parallel it also was not able to show the Fotos. I then copied all the Fotos from the HDD to an SSD using different cable & Sata port -> still same issue.
(I have German Windows, so do my best to translate the errors etc.)
I then recognized that everytime there is a freeze I have a warning in Windows Eventvwr.
storahci - ID 129 - Reset to device, \Device\RaidPort3, was issued.
So the disk was reset and during that time not accessible -> FastRawViewer waiting on disk response -> hang
Since I have a dedicated disk for my Fotos Windows itself (and other applications) were running fine during the reset of that disk.
I did some research and found it was related the the AHCI Power Management Options set with the power plan "AMD Ryzen Balanced". Those options are not visible per default, so you first have to enable them via registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\0012ee47-9041-4b5d-9b77-535fba8b1442
0b2d69d7-a2a1-449c-9680-f91c70521c60 -> Attributes: replace 1 with a 2
dab60367-53fe-4fbc-825e-521d069d2456 -> Attributes: replace 1 with a 2
Afterwards you will see two new options in:
Control Panel -> Hardware and Sound -> Power Options
Here select the Power Plan with "Change plan settings" -> "Change advanced power settings"
AMD Ryzen Balanced
Amd Ryzen High Performance
The solution is:
a) Change the Power Plan to "AMD Ryzen High Performance" -> this of course has also effect on other Energy Saving options
or
b) Change the two setting for hard disk (after enabling them with registry change as shown above)
- AHCI Link Power Management - HIPM/DIPM = Active
- AHCI Link Power Management - Adaptive = 0 millisecond
After I changed those settings I did not experience any of the hangs anymore, so I hope this information is usefull for others.
AMD Ryzen Balanced
The solution is:
or
