Leonard Shepherd
I disagree with your analysis.No, they just record photons.Sensors record the brightness of the light falling on them when an exposure is made - the brightness is the same for the same aperture regardless of the format.
Are you saying film cannot record the level of brightness in an image because that takes place in the grain structure and during the development?
You are not right.Noise isn't produced by ISO settings. An imaging sensor having x times larger area than another, will also have an x times larger photon density for the same lens aperture.At lower ISO's, when technology and MP are the same, there are negligible image resolution and noise differences in the field between DX and FX.
The sensor records the image at base ISO and then the recorded brightness is electronically magnified at higher ISO's, producing electrical noise at higher ISO's.
Crank up the ISO and there is more noise.
Doctor, doctor - although I work in the Antarctic where their are no land mammals - I know from the internet I have got rabies - and want you to cure it.
The reality is there is negligible difference in image resolution or noise at lower ISO's between DX and FX, MP for MP and technology for technology - and usually any difference is not detectable outside of a laboratory.
It seems to be a current internet myth that pixel size has an easily detectable effect on noise and resolution at lower ISO's between DX and FX.
Those who regularly shoot DX alongside FX (with similar technology) know first hand the myth is not true.
Whether the Z50, courtesy of a later Expeed processor, has equal or a little better noise performance than the Z6 and & Z7, remains to be clarified - but some sources imply that it has.
