Hi Folks, Can someone explain the reason that all lenses are stopped down for focusing unless you are using an aperture below this.
If you say have a 50mm F1.8 on a say D800 it will use F1.8 for focusing whatever aperture you are shooting at.
On a Z6/Z7 the same 50mm F1.8 will use F5.6 for focusing unless you are going to shoot at an aperture below that, in which case it will open the aperture further as required.
Is greater accuracy of focus not obtained at max aperture or am I missing something?
I was thinking that it would be easier to get correct focus with a wider aperture.
