T
Threaded
Guest
Not sure why you’ve decided that X-Trans II is some product of my imagination, but I can assure you that it was Fuji who marketed and introduced it as a “new” sensor, no matter how similar it may have been. It was a physically different package with added phase detect pixels which didn’t exist on the original first gen sensor.The X100 series received the 16mp and 24mp sensor after the X-Pro series. The X-E series...the same. I don`t believe there were 2 totally different 16mp sensors like you seem to think. I think it was the same sensor with a different processor.So what about the XE line or the X100 - they’ve been updated just as frequently as the XT’s in the past and used each new sensor in turn - why are they now skipping a generation all of a sudden?because these models are updated more frequently than the X-Pro series.If you are telling us that Fujifilm changed their release sensor debut schedule - sure - the 26 MP sensor didn`t debut with the X-Pro line this round - it debuted in the X-T3 first. Then jumped to the X-T30 - which means it missed the X-Pro3.That’s not what I said at all. All I said is that the X-Pro1 was the first to use the 16mp sensor and the X-Pro2 was the first to use the 24mp sensor. Now you are telling me that Fuji is going to put the 1 year old sensor from the $899 X-T30 into it and try to sell it as something special based on a paint job and a hidden screen? It’s possible but it is also possible that we see something new.Fujifilm has never differentiated their models based on sensors - it has always been - reuse the same sensor across the entire model range - then refresh with the next one.
The XE series has literally been X-Trans I, II and III in turn.
ONE x-pro model has been released with a major sensor upgrade. It’s only happened once!It`s not a problem. It´s a fact. Each X-Pro model has been released with a major sensor upgrade. That cannot be disputed.You’ve answered your own question, the XH1 was Fuji’s most expensive new flagship model ever when launched (pricier than the X-Pro2 had ever been), and it had already waited for both the XT20 and XE3 to launch with the same sensor.Name one instance where a low end model got the latest sensor before other high end models? The X-T30 would be the first if the X-Pro3 has this same sensor. Well, the X-H1 was the first I guess but they banked on ibis as the big feature.I personally feel they have too many models using the same sensor but whatever, here is their current line up that needs sensors if they are keeping the same lineup. 2 of the 5 have the 26 MP sensor (X-T3 and X-T30),
How about the XT1 - very much a high end flagship model when launched, and it used the same sensor and processor from the XE2 about a year earlier. Unlike the XH1 it was a huge success despite being almost entirely the exact same camera in a different package. How do you discount that?
The problem you have is you’re putting all of your stock in just one rather limited “historic pattern” - namely that in the X-Pro line’s *one* previous update, it got a new sensor.Not sure which historic pattern you are referring to.3 others need sensors (X-Pro3, X-H2, X-E4)
1) X-Pro#
2) X-T#
3) X-H#
4) X-T##
5) X-E#
Concernedly possible that new sensor is in the works for the next 3 models and would help in them differentiating their models but not their historic pattern.
As I said before (and you did ignore above) there’s already precedent with the XT1, which launched a similar period after the XE2 with exactly the same internal hardware and immediately became Fuji’s most successful premium flagship model and a breakaway hit.When did I ignore that? I simply am trying to say that a sensor is released in the high end cameras first and then it trickles down to the low end. The X-H1 is the only exception. Now, you are trying to say that the 26mp sensor will be used in a high end model 6-8 months after a low end model. This is not the norm in the camera world or for Fuji. Especially when the X-Pro3 will be very expensive for APSC.The broader pattern you’re ignoring is that in each new sensor/processor generation, *every* model uses the same gear.
I completely agree there wasn’t a huge difference, but accepting the existence of X-Trans II isn’t a matter of belief, it really did happen, and while it made no difference to IQ (at least in raw) it did make a big difference to AF over and above the improved processor alone.Huh? We had a 16mp sensor, a 24mp sensor, and a 26mp sensor... you can believe the X-Trans II crap, but effectively there wasn`t a huge difference there.Admittedly the first generation (heavily criticised at the time for its slow processor and contrast only AF) was unsurprisingly short lived, but after that we had X-Trans II in literally every model line bar the X-Pro (which was likely heavily overstocked at the time), then we had X-Trans III in literally everything, now we have X-Trans IV in.. just two models, one high and one low end? You really think so?
Similarly there’s barely any IQ difference between the 24 or 26mp sensors either, but in the mirrorless world sensor upgrades aren’t just about IQ - once again the real driver is autofocus (not to mention video).
Not sure what you’re seeing when you look at the X-Pro3, but I certainly see “something different”, for better or worse.I still believe that it will be a hard sell to put this current 26mp sensor in the X-Pro3. I understand you think I am wrong. However, the X-Pro series is on a 4 year update cycle and that is why I believe they need to do something different. Well, more than just a paint job and a gimmick screen.
