G1X Mark III with filter adapter
Started Sep 28, 2019 | Photos
riveredger Veteran Member • Posts: 3,860
Just sharing some photos of the camera with the JJC filter adapter.  Also, included one with the 270EX speedlight.
Front
3/4 angle
With 270EX II
richsfusa Junior Member • Posts: 47
Re: G1X Mark III with filter adapter
What is the advantage of using the JJC Filter Adapter instead of just screwing a 37mm filter directly onto the lens without an adapter?
 richsfusa's gear list:richsfusa's gear list
Canon G1 X III Canon EOS R5
OP riveredger Veteran Member • Posts: 3,860
I don't know that there is a clear advantage.  I prefer the larger 49mm lens cap and having the lens hood, though.
mouzhik
mouzhik Regular Member • Posts: 404
There is one simple optical truth: the nearer is the filter to the lens, the less parasite light and flare you get and the better it is.
That's why I put a 37mm filter on the lens here and screw the hood on it.
 mouzhik's gear list:mouzhik's gear list
Canon G1 X III Ricoh GR III Canon EOS 5D Mark II Canon EOS Rebel SL1 Canon EOS M6 +13 more
I have not noticed any ill effects yet.
ssepan1
ssepan1 Forum Member • Posts: 86
I ran across some discussion about this topic here:
https://www.dpreview.com/forums/post/60626230
 ssepan1's gear list:ssepan1's gear list
Nikon D700 Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Canon G1 X III Gimp +5 more
OpticsEngineer Veteran Member • Posts: 7,822
Thanks for the link.  That is a worthwhile read.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
Swerky Contributing Member • Posts: 793
“The Canon technicians I spoke with told me that the use of the Adapter would also reduce vignetting with some filters... which might occur if the filters were placed directly on the end of the lens.”
This is from the thread shared below. Funny thing is I had read that thread and discussed that issue with a friend. But a year later I had forgot about that and purchased for my G1X III a polariser filter that screws directly on the lens and then screwed the hood over that. Result is I got heavy vignetting at wide angle that just wasn’t usable. Had to unscrew the hood when I had the filter on. Fine. Anyway it’s not necessary in all landscape scenarios to keep it on.
Nothing to read here.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
But how easy is it to access that tight space between the filter and hood to screw and unscrew the filter? I got a polarising filter that fits directly on the lens. Screwing a hood over that results in heavy vignetting at wide angle. Luckily I don’t always need the filter.
