Michael Meissner
I hardly ever use manual focus, but I have my main Olympus cameras (E-m1 mark I, E-m10 mark II) set up so that when I manually focus, I turn on the enlargement and focus peaking options. While my 12-40mm f/2.8 lens has a focus clutch ring, I rarely use it.
I just bought a used 12mm f/2.0 lens from keh.com and I was making sure it was working (yep). So after doing the auto focus tests, I moved the clutch ring to try manually focusing. I was surprised that when I used the clutch ring, it did not magnify the image nor turn on focus peaking.
If instead I either use the super control panel to set the mode to MF or SF+MF, it does what I expected and enlarge the image and turn on focus peaking. Since I rarely use it, the inconsistency isn't that important to me, but it did seem weird that the MF options aren't automatically enabled when the clutch ring is used.
