randello88
Well-known member
- Messages
- 119
- Reaction score
- 8
It looks like a dust spot but you need t o post a full size version of the file from the camera if you want us to see the real problem.fuji x100f, in every picture. It is in rue middle of the picture and it is visible almost only when there is the blue sky behind it. Is it a big deal? What is it?
It's almost certainly dust on the sensor filter. The best way to confirm it is to aim the camera into blue sky and ramp up f-number to at least f/16. If it's very visible and well defined in those conditions, it's dust. (You'll probably see more of the little buggers too.)It looks like a dust spot but you need t o post a full size version of the file from the camera if you want us to see the real problem.fuji x100f, in every picture. It is in rue middle of the picture and it is visible almost only when there is the blue sky behind it. Is it a big deal? What is it?
No.Isn’t it strange that it is exactly in the centre?
If your camera has dust on the sensor (most cameras do) it's going to be most visible when shooting against a solid color and a small aperture.Is it normal/common to have some dust that pops out against blue sky or is it a big problem?
How would anyone know that without seeing similar photos taken when you first bought the camera?Since my camera is a fixed objective one, is this problem existent since i bought the camera?
So come back and ask then.No possibility to check my older picture for many days to come. Thanks
So after you get home, post a sample for us to see.Yes, I’m in namibia, not at home
If you have dust on the sensor, then the obvious answer is "yes."I was asking if it is possible that dust gets in a fixed objective camera.
There's just no way anyone can know that from the phone snapshots you've posted.It doesn’t seem too obvious to me. Maybe the dust was there from the assembly at the factory. Thank you for the answer, anyway.
Yes.So do you think having dust on the sensor is a minor issue? You should just keep using the camera without worries, maybe revolving the problem in post-production? Ì know those are newbie questions, hope you can help.
Whether it's just a minor distraction that nobody else notices or major one that's frequently visible in your shots will vary depending on the size or quantity of dust spots and the nature of your images. As you've discovered it's easier to notice in blue sky because it shows "texture" that you know shouldn't be there. If it appears where there's usually textural detail, then it's likely to be completely unnoticeable. Also, as noted, shooting at higher f-numbers will make it more noticeable, so if your photography involves a lot of deep DOF imaging that requires very high f-numbers, you'll see it more often.So do you think having dust on the sensor is a minor issue? You should just keep using the camera without worries, maybe revolving the problem in post-production? Ì know those are newbie questions, hope you can help.
