waloshin2015
Leading Member
- Messages
- 760
- Reaction score
- 286
It is very sharp, i wonder if you will get the usual sharp portrait chatter. I think sharpness is fine but i would say it's overexposed a good stop, maybe more. That sensor is fantastic, maybe drop exposure and boost shadows a bit to keep the right side lit.
Today that is true.Hello Tedolf,
If you would be so kind:
It seems that shallow depth of field portraits are very common.
Any photographic technique is acceptable when it supports the artistic theme of the work. Whenever any artistic technique, photographic or otherwise defeats or is in conflict with the theme of the work it is not acceptable. Just making the ears out of focus because you can is not thematically justified.One, perhaps both eyes are in focus, then everything melts away leaving the ears etc ,mostly out of focus.
When, if ever, is this acceptable?
That is my best effort.I searched Google but found no answer.
tedolphThanks![]()
