H
Neither filter would be of benefit. The only thing I can think that might give you an 'artsy' look would be to use an ND filter which would really blur aurora.
But, they are gorgeous on their own merit.
David
You sure about that?
Check out what this guy got in IR:
http://photocamel.com/forum/infrared/226340-aurora-borealis-infrared.html
I think that you are getting mixed up between filters that only allow IR or UV to reach the sensor and filters that stop any IR or UV from reaching the sensor.
As somebody else has pointed out, digital sensors already have filters on the front of the sensor that stop about 98% of UV or IR from reaching the sensor. That is why the UV filters that some people use for lens protection have no optical effect.
If you want to take an image using IR or UV only, you first of all have to pay somebody to remove the relevant IR or UV filter from the front of the sensor. That ruins the camera for normal visible light photography and will invalidate your warranty. You then need to find a filter that allows only UV or IR through. This is what infrared photographers do. Normally they adapt an old body to use for IR only.
Google “infrared photography” to learn more. I haven’t heard of anybody doing UV photography.
