Many years ago, if you had a digital camera with 6MP, and using a wider aperture, the area that'd be seen in focus would be larger. Today's high resolution sensors, Pixel Shift, etc. allow much more detailed images, but the OOF transition is very noticeable.
Worry 1. I don't understand this. The transition from being in focus to out of focus is a gradual one based on the geometry of distance from the focus plane. It doesn't go in steps so I don't see how it can be more or less noticeable just because the pixel density changes.
Just to be clear on this, I assume that you are looking at all pictures at the same
physical size. If you are looking at 100% then the physical size of the image changes and DOF changes with it; so the transition won't be in the same place. As a 100% image on a high-MP sensor is bigger than on a low-MP sensor you enlarge the details more so
everything becomes more defined, not just the transition.
Worry 2. You seem to be talking about comparison between low-MP and high-MP images. But unless you are comparing two photos taken effectively at the same time from the same place with the same lens and exposure settings and viewed in exactly the same way there isn't actually anything to compare. Without that all you are doing is comparing vague impressions.
of course, you can always reduce resolution. But when you may want to use that resolution, you may find that you'd maybe had been better with a larger area in sharp focus.
Have you considered this factor? Is there a calculator based on "discernible DOF" that takes into account resolution?
It's easy enough to do this with any DOF calculator that allows you to choose your own value of circle of confusion.
First, CoC is used to define how
blurred a real point looks by virtue of being away from the focus plane. You can sometimes see it called the
blur circle; and this is actually a better name for it. Something that is really a point will look blurred in a photo for several reasons, even when it is at the focus distance; and standard DOF calculations ignore all of them:
Lens resolution: unless the lens is perfectly corrected its aberrations will always mean that what should be a point is actually slightly blurred.
Pixel resolution: most cameras merge the output from several sensels into a single pixel; this introduces blur.
Diffraction: all apertures cause diffraction because of their edges; the effect is trivial at wide apertures but becomes significant at small apertures.
Worry 3. As these all increase the real blur in the image it means that they all (individually and collectively)
reduce the DOF you see compared to standard calculations. So using, for example, a higher-MP camera will yield a real DOF that is
deeper than with a lower-MP camera (all other things being kept equal). But you seem to be talking as though the higher-MP camera reduces DOF("thinner" as in your thread title).
Each of those factors creates its own blur circle. So to take account of them you need to find out the magnitude of each and add it to the CoC to get a bigger total, blur circle.
Assuming a high quality lens you can probably ignore lens blur - whatever its size it will be the same whatever sensor it's in front of. And while there are concerns that current very high MP cameras can out-resolve lenses it's probably safe to say that lens resolution is generally less of a factor than pixel resolution. For pixel resolution it's probably reasonable to take the size of a single pixel; on FF that gives 12 microns at 6MP (if there ever was a 6MP FF camera; at 12MP the pixel size is about 8 microns), 4.4 microns at 36MP. Diffraction blur can be calculated like this
https://www.photopills.com/calculators/diffraction
Note that because standard DOF calculations ignore these then whatever the calculations say, if you view an image under the exact conditions assumed in the calculations the real DOF will be a bit shallower than calculated.
Now, just to complicate things, if you
add the blur circle sizes noted to the assumed CoC you get a bigger value and the standard calculations take this as the amount of blur you are happy yo accept; so the calculated DOF
increases! but we want to know how much DOF
decreases so we have to fool the calculator by
subtracting the values.
Here's an illustration. I'll take a 50mm lens on FF at f/5.6, focused at 10m. This is less than the hyperfocal distance so we can see the results for both ends of DOF.
The standard calculation, which uses 30 microns for CoC, gives a total DOF of 24.8m (6- 30.8m). If I use the 12MP camera and assume its pixel blur is 8 microns (as above) then I change CoC to 30 --8 =22 microns. This gives a total DOF of only 13.1m (6.7 - 19.8), which is much less than the standard calculation.
Going to the 36MP sensor I assume 4 microns of pixel blur (because the DOF calculator I'm using doesn't allow fractions) so CoC goes to 30 -4 = 26 microns. That gives a total of 17.8m (6.3 - 24.1m), which is still shallower than the standard calculation but noticeably deeper than the 12MP sensor.
Would it be sensible as resolution increases, to maybe want to use a bit wider DOF that we where used to in the past?
Worry 4. This seems back to front. First, I can't see why using a different body would make me want a different DOF - what I see in the picture is what I want. If (whatever the calculations say) I was happy with the DOF given by a low MP camera then that's still what I want.
What I think you may be getting at is not how to
change DOF but how to get
the same DOF by altering the camera settings. To do that you go to the DOF calculator, find the
actual old DOF using the appropriate modification of CoC; then change CoC again to the newer sensor value; and then adjust aperture until DOF reverts to the old value.
Using the illustration from above, if I change f-stop from f/5.6 to f/4.8 I get a total DOF of 13m, which is effectively the same as the old 13.1m value.
While the title is obviously answerable with a "no", in practice, I think this is something that has made me consider extending DOF a bit more than I was used in the past, especially, if I consider that I now also have more chance to crop as needed.
Don't forget that cropping changes everything so you'd need to start with a new sety of calculations.
Gerry
___________________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
[email protected]
