PamperedPainter
New member
- Messages
- 9
- Reaction score
- 3
I am an oil painter specializing in floral still life. I am currently using a cheap soft box fitted with four 35 watt LED bulbs purchased on Amazon. If I only worked from photos I would use a more powerful flash, but I also work from life so I need a contiuous light source.
My current set up is not bright enough and the color is also a little off. I am considering the Aputure 120d ii or the newly announced Aputure 300d ii. I will be using the light in a soft box. I have read the 120 has about 180 watts with very accurate color, 30,000 lux and .5m.
The 300d ii will have 90,000 lux at 1m. Is this light over kill for my needs? I understand it will be available July or August and cost about $500 more than the 120d ii.
I am attempting to recreate northern light used by the masters for the purpose of creating an oil painting. Below is a smaller set up I photographed this morning and as you can see I don't have enough light to increase my depth of field.
I have looked into Godex and am concerned about the color accuracy. Anything else I should consider? I would appreciate your input on a good light for my needs.
Julie
Julie
