Hello.
I'm about to get a 120cm Octabox this week for my TT685-F.
Has anyone here tried using the same speedlight inside the octabox with white diffuser?
Doing so is quite common but you want double diffusion.
If the hot-shoe flash mounts inside the softbox then the bounce off the back of the softbox is the first diffusion and the fabric front is the second.
If the hot-shoe flash mounts outside the back of the softbox then you need two diffusers, one fabric diffuser half way to the front and the front fabric diffuser.
Did it produce a nice soft light for newborn or do you have an idea if it will?
For soft light you want a diffuser as large as or larger than the subject and you use normally use the diffuser at distances between 1 and 2 times the diameter or diagonal of the diffuser for the best combination of softness and light fall off across the subject.
You can get by with somewhat smaller diffusers for a full length portrait. Details are smaller vs other types of portraits so the slightly harder light helps make the details more visible. I use a 43" white reflection umbrella or 40" softboxs very successfully for full length portraits.
Your 120cm (48") softbox should be large enough for good soft light, especially for waist up shots of a seated mother with child.
I'm not sure if the size of the octabox is too big for the speedlight (have to use it for low power) but will it be sufficient for portraits? There's the 90cm square softbox (or 90cmx60cm rectangular one) but I might still go for the 120cm octabox because I'm considering to use it for parents with their newborn as well. or should I?
You are going to be light limited. I shoot at ISO 100 and f/8-f/11 with about 200Ws to 300 Ws of power from a studio strobe and my 40" softboxes. A hot-shoe flash like your's has the equivalent of about 60Ws of power when diffused. That means you will be shooting with at least 1.8 stops less light output from your softbox.
Shooting with this low power means you will have to boost the ISO and/or open the aperture. Doing either increases the ambient light exposure, giving you less control of the subject and background lighting.
I've read so many photographers are using 50" Westcott (mega apollo) but I'm limited on my budget.
I would appreciate for any helpful feedbacks.
Thank you.
If you are very budget limited then get a 43"-45" white umbrella with a removable black backing for your diffuser. You can get one of these for less than USA $20. These will give you great light if you learn how to use them
Save your money until you can afford to buy something like the Godox AD200 or AD400 and a proper Bowens mount softbox.
Here is a simple setup that takes advantage of using a hot-shoe flash and walls for reflector/fill light. This is based on the Good Light Portrait Corner of Michael Zelbel.
The Good Light Method | A Revolution In Flash Photography Tutorials
Move furniture out of a corner with white walls if you want simple portraits.
Place the subject about a foot from each wall.
Position the rim of the umbrella your arm's span from the subject. Extend your arms out to the sides. Almost touch the subject's nose with one index finger and touch the rim of the umbrella with the other index finger and the umbrella will be the right distance from the subject.
At this distance you can use the umbrella for everything from a head shot to a full body portrait. For full body portraits the feet will be a little underexposed but that is good - the viewer's attention is drawn upward to the brighter face.
The umbrella should be aimed down at the face and upper body. The height should be so that 1/3 of it is below the subject's eye level to give you nice catchlights.
Use ISO 100 and f/4.
Set the shutter speed to the Sync speed minus 1/3 stops to make sure that any flash will sync and not give you a horizontal vignette in your images.
Set the flash to Manual, NOT TTL, and adjust the flash power until you get a good exposure of your subject.
If you have a flash meter it will probably give you the right exposure but it is easy to check.
In post the brightest diffuse highlight (non-specular highlight), which is usually the cheek closest to the light, should read 87% ± 2% in Lightroom or 218 ± 6 in Photoshop.
Once you determine the correct flash power to give you the correct exposure you never change the flash power again as long as you keep the umbrella the same distance from the subject. This holds true indoors whether your subject is in the corner or seated on a chair in the middle of the room.
Using the String Method for Consistent Portraits | Photoflex Lighting School | Photoflex
KISS - one ISO, one aperture, one shutter speed, and one flash power.
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
