Hi guys. I'm thinking of buying a micro four thirds camera, possibly an OM-D. Most of the bodies I can afford come with 1.4 million dot resolution viewfinder. Is this sharp enough, or do you see a lot of pixelation at this resolution? Would a 2.3 or 2.5 million dot EVF be significantly better?
Thanks for your advice!
Look, in the 1960's people were over the top happy, just having exchanged their B&W for a color tv.... with 480 lines. And they remained happy for the next 30 years.
In the 80's, PC monitors had 640x480 pixels (0.3 mio pixels) and we were proud to afford one of these. Then came 1080x768, 1k, 2k, 4k and now we are talking 8k.
It is completely painless upgrading to a higher resolution. Going back is the problem. It's human nature. Once we got used to a certain quality, we just do not like to go back.
You ask how much is the minimum for an EVF. I would answer this way:
it is whatever your previous camera had. Anything less, and you will be unhappy. Anything more, you will forget about one week later, and it becomes your new normal.
Lol. My previous camera had none! Just the LCD.
There you go. Any viewfinder is better than none. I have a GM1 without it, and recently bought a GM5 with viewfinder (it is otherwise the same camera). I do not care about it's resolution, I do not care it is a very small viewfinder. It is a huge improvement in usability for this camera.
Some say the VF is only used for composing the picture. It does not make your pictures any better. This is generally true, but it is not always the whole truth.
- I like to use use manual focus a lot, probably more than others. Also, think of manual lenses, think of close-up and macro work. Now, I am not entirely sure if and how EVF resolution affects either/or the accuracy and ease of use of manual focus. After all, there are helpers such as focus peaking and digital zoom. All I can say, is that I find achieving manual focus easier and faster on my Pen-F and EM5-2 than on the GM5. I like to think it has to do with both EVF magnification AND resolution, as well as panel contrast and the quality of the EVF optics.
And think about it, if the EVF had the same resolution as the sensor, there would be no need anymore for the focus peaking helper! You could see focus directly.
- I use the EVF, together with the histogram helper, for adjusting exposure. The histogram tells me about the overall exposure, in the EVF I see where the highlights and shadows are and can decide which ones I want to prioritize for the effect I desire.
- The EVF does not need to be color accurate. You do color adjustments on your calibrated PC screen. I prefer the better color saturation and contrast of the Pen-F's OLED to the EM5-2's panel. But the panel is not everything, the quality of the EVF optics is at least as important, and probably more so.
- I rarely do action/sports, but if I did EVF panel speed would be an important factor to consider.
- I wear glasses, so the EVF's eye relief is an important factor for me. Eye relief is how far away from the EVF lens my eye can be, whilst still seeing the whole field of view. I do not like having to press my glasses against the EVF rubber, it leaves marks on my glasses. More eye relief is better, but harder to achieve optically. True, one can take the glasses off and use the EVF's diopter adjustment to see the panel sharp.... but some people cannot do that because they have significant astigmatism, and the diopter cannot correct for that.
....and BTW, why are extended rubber EVF hoods so expensive on certain camera makes? Panasonic wants something like US$50 for that GM5 rubber piece that looks like it costs 50 cents to make.
