M Kitzman
The first image is large format shot on a Linhof with a 110xl supersymmar by Schneider-Kreuznach. The lens is considered one of the finest at the time. The image was shot in the morning during the summer and it is hard to replicate the same lighting at this time.
The second image is the GFX 50R with the Fuji 32-64 zoom. I used photoshop to correct the perspective, not having the advantage of the rise of the LInhof. I also cropped out about a quarter of the foreground to more match the Linhof.
What is sad is the LInhof image was taken about ten years ago after the church had undergone a major restoration and now we can see the deterioration of much of the stucco work. Seems it was not properly sealed and it is just melting away.
The Gfx comes close and in a similar light I think it would produce an equally satisfying image. Shows you how far digital photography has really progressed.
I ordered the Fotodiox adapter that marries the gfx to the Linhof and will re-shoot the image next week. This will involve stitching two to three frames with camera oriented in the vertical position. I will share the results with you. The 4x5 allows fairly good movement with the Schneider-Kreuznach 210 and the NIkon 300 large format lenses. The 110xl can also be used but there is very little if any movement since the rear elements of the lens have to mounted very close to the sensor. The ability to use the camera movement and the same time greatly increase the resolution should result in some killer images. Hope you enjoy the comparison thus far. MK
4x5 St.Cajetan, Auraria Campus, Denver
Fuji Gfx 50r
Fuji Gfx 50r
