SoupOrPhoto
- Messages
- 1,097
- Solutions
- 2
- Reaction score
- 452
The good news is that the forecast for Sunday night is now predicting clear skies in my area (although it is changing daily). The bad news is that the temperature is expected to be below zero F (which is like -167.8 C--or something). Gear I'm using:
Primary:
Nikon D750
-- TetherTools CaseRelay power via USB to large Li battery (also have battery grip)
-- Long USB cord to laptop (warm, in house/car) - rated only to 32 deg F
Nikon 200-500 f/5.6
iOptron SkyGuider Pro (connected to battery via USB)
Secondary:
Nikon D90 with battery grip on fixed tripod for moon trail (no cables or tracking)
My largest concern is that the cables may get too cold and not work--but I've never tried using them in temperatures this low. I'm also concerned the the SkyGuider Pro may be affected by the cold. I think that the battery will be fine as long as the cables work as it is nearly 30,000 mAH and so it should provide enough power even if efficiency is reduced.
Have others experienced trouble at very low temperatures? Are there other issues that I'm not considering? I can insulate the battery but is there an easy way to insulate the cables (do I need to)?
Thanks for any advice.
Primary:
Nikon D750
Nikon 200-500 f/5.6
Secondary:
