Which LUT to use for C-Log?
Mr Marco
Member
CH
I spent a bit of time trying to figure that out too - they don't make it straightforward, do they?! My conclusion, anyway, was that there is no Canon LUT that fits the bill, though I could of course be wrong about that. I did find, however, that the C-Log LUT that is built in to FCPX was perfectly satisfactory. I'd suggest trying it out and seeing if it meets your needs.
Edit: When I was looking at this issue it was re the 5D4 though I suspect that the same analysis applies
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
Thank you for your reply.
That is true. The built in one looks quite nice. Do you know where Final Cut saves it? I want to be able to apply it with the custom LUT effect and not on the clip info panel.
Btw: I got some fine results with the: BT709_CanonLog-to-BT709_WideDR_65_FF_Ver.1.1.cube
Sorry, can't help you there.
Great! Many thanks for sharing this. I will try it out and compare.
Best wishes
Shane
For what it's worth, I like the BT2020_CanonLog-to-BT709_WideDR_17_FF_Ver.1.1.cube
I like saturated colors. It starts me closer to where I want to be in the end.
Joe
