cjb
Leading Member
Some background: I have a big trip coming up and I decided to purchase the GFX 50R, GF45 and GF110 with the recent aggressive markdowns. That means I'll be taking 3 bodies on this trip: Fuji X-H1, Canon 5DSr, and GFX 50R. Plus glass.
I have a number of Canon EF lenses I'm interested is being able to use on the GFX at some point, so I took the plunge and bought the Techart Pro adapter. The following represents some initial tests with the Canon EF 11-24 only. I have not tested other lenses yet, but based on some quick tests, I'm optimistic.
As a reference, I also took the same pictures using the same 11-24 with the 5DSR. All tests were on a tripod with aperture priority and 2s shutter delay. The cameras were allowed to do AWB and AF on their on. Both were AFS single shot. All tests were at ISO 400.
I'll be the first to say these tests are not rigorous nor complete, but they do represent some effort to compare things side by side.
Some observations:
The following images are a small subset of the test. They are JPEG exports from LR, with lens profiles applied. All other LR settings were default, including color profiles and sharpening of the GFX images (which probably should be dialed back a bit). If I can find a place to post RAWs, I will.
5DSr + 11-24 at 11mm, f4
GFX 50R, 35mm AUTO ON, + 11-24 at 11mm, f4
GFX 50R, 35mm AUTO OFF, + 11-24 at 11mm, f4 (with vignetting)
Some observations:
- Techart says don't try to do AFC with the TechArt adapter. It might work, but probably not. That means no BIF with the GFX and a 400/2.8.
- AF performance with the GFX 50R + 11-24 was acceptable, but noticeably slower than native Fuji lenses or with the 5DSR + 11/24. Focus hunted a little but, but locked. This might be different in low-light or low-contrast.
- I tested just 2 apertures in this initial test. f4 and f8, and I thought those represented typical working apertures. I did not not notice any obvious surprises; there might be subtle differences between the 2 cameras, but not significant to my eye.
- The Techart reported the 11-24 as 24mm, even when it was at 11 mm. Probably a bug.
- The GFX has a 35mm Auto mode that will crop the sensor to about 30mp in order to avoid vignetting. I did not detect this feature initially, so wound up repeating the tests just to see the amount of vignetting that was happening. As a result, I have some tests with 30mp files and 50Mp GFX files. The amount of actual vignetting varies with focal length.
- I can apply Canon 11-24 lens profiles to the GFX image using the latest LightRoom settings. Honestly, I thought the resulting images look pretty good.
- I was shocked at the image quality from the GFX compared to the 5DSR. The GFX was noticeably better at the edges, even when comparing 30mp GFX files to 50mp 5DSR files. It makes me wonder if there was something off with my technique with the 5DSR, or if some other parameter was in play (e.g. AF differences, field curvature, or something).
