Is there a reason that you're blaming the flash rather than the camera? Have you observed different behaviour with a Sony flash?
All I know is the combo isn’t working well, I can’t conclude which component is truly to blame and I don’t have access to a Sony flash. If somebody has an A7Rii and has tried both Sony (or any other brand for that matter) and Godox for on camera TTL shooting I’d like to hear their feedback. I’d be willing to buy another brand of flash for on camera shooting (the Sony’s are too expensive for me), but I do like the Godox system for non TTL off camera work.
However, although I can’t conclude which component is causing the problem, the camera itself is simply not exposing the scene properly when using on camera ttl Godox flash, for instance I can shoot at 1/100s f1.8 and iso 1600 and the shot is reasonable well exposed, but then if I go to 1/250s f6.3 the auto iso remains at 1600 and the shot is massively underexposed irrespective of flash comp or exposure comp as if there’s a software bug not allowing iso to go above 1600?
Are you saying that the entire image is underexposed, or is it just the areas not lit by the flash that are underexposed? Can you post some examples?
Also, have you tried setting the camera's exposure manually? Are you unable to select an ISO above 1600 when a flash is mounted and on?
I’ll post some pictures when I get back to the house, as they say a picture paints a thousand words.
Ok, here's a series of example pictures, but firstly let me summarize settings:
- For this first portion of shots the camera is in Manual mode with iso set to auto throughout the below series (range set to 100-6400). I advise below when this changes.
- Fill flash selected on camera
- For these examples I used multi metering mode. Exposure comp was set at zero throughout.
- Flash is in TTL mode
- All shots taken in RAW and processed without any exposure adjustment.
Benchmark shot with no flash. 1/200s, f1.8, ISO 6400
Flash comp = 0, 1/200s, f1.8, iso 1600
Flash comp = -1, 1/200s, f1.8, iso 1600
Flash comp =-2, 1/200s, f1.8, iso 800 (why is it setting my iso lower with less flash comp?)
Flash comp = -3, 1/200s, f1.8, iso 400
I then changed f stop to f8.
Flash comp = 0, 1/200s, f8, iso 1600
Flash comp = -1, 1/200s, f8, iso 2000
Flash comp = -2, 1/200s, f8, iso 2000
Flash comp = -3, 1/200s, f8, iso 1600
I then switched to Aperture Priority mode as another poster just advised his setup was working and i think they were in Aperture priority mode,
so all pictures from here onwards are in Aperture Priority mode.
Flash comp = 0, 1/60s, f8, iso 2000
Flash comp = -1, 1/60s, f8, iso 2000
Flash comp =-2, 1/60s, f8, iso 2000
Flash comp = -3, 1/60s, f8, iso 2000
E front curtain off, Flash comp = -3, f8, 1/60s, iso 2000
ISO did actually go above 1600 this time, seemed to stall out at 2000, but clearly needed to be much higher to correctly expose. Is this making sense to anybody?
FYI: I'm new to on camera TTL shooting so don't assume anything regarding my settings being correct, this could be a rookie mistake in settings?
